State of the art in wind turbine aerodynamics and aeroelasticity, Progress in aerospace sciences, vol.42, pp.285-330, 2006. ,
Novel structural modeling and mesh moving techniques for advanced fluid-structure interaction simulation of wind turbines. IJNME, vol.102, pp.766-783, 2015. ,
Offshore floating wind turbines-An aerodynamic perspective, 49th AIAA Aerospace Sciences Meeting Including the New Horizons Forum and Aerospace Exposition, vol.720, 2011. ,
CFD simulation of a floating offshore wind turbine system using a variable-speed generator-torque controller, Renewable Energy, vol.97, pp.230-242, 2016. ,
Demonstration of a coupled floating offshore wind turbine analysis with high-fidelity methods, Journal of Fluids and Structures, vol.62, pp.272-293, 2016. ,
Aerodynamic simulations of offshore floating wind turbine in platform-induced pitching motion. Wind Energy, 2016. ,
The platform pitching motion of floating offshore wind turbine: A preliminary unsteady aerodynamic analysis, JWEIA, vol.142, pp.65-81, 2015. ,
Computational freesurface fluid-structure interaction with application to floating offshore wind turbines, Computers & Fluids, 2016. ,
Etude expérimentale du comportement dynamique d'uné eolienne offshore flottante soumise l'action conjuguée de la houle et du vent, 2013. ,
Review of computational fluid dynamics for wind turbine wake aerodynamics, Wind energy, vol.14, pp.799-819, 2011. ,
Solution of high-Re. incompressible flow with stabilized finite element and adaptive anisotropic meshing, CMAME, vol.267, pp.65-85, 2013. ,
Massively parallel anisotropic mesh adaptation, IJHPCA, p.1094342017693906, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01487424
Small scale tests of floating wind turbines in the wind and wave flume of Luminy, pp.18-20, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01221643
A continuum method for modeling surface tension, Journal of Computational Physics, vol.100, pp.335-354, 1992. ,
Simulating 2D viscous flow around geometries with vertices through the Diffused Vortex Hydrodynamics method, CMAME, vol.302, pp.147-169, 2016. ,
Wind Tunnel Tests of the NACA 63-415 and a Modified NACA63-415 Airfoil. Forsøgsanlaeg Risø, 2002. ,
Convected level set method for the numerical simulation of fluid buckling. IJNMF, vol.66, pp.324-344, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00595325
A modified highorder spectral method for wavemaker modeling in a numerical wave tank, EJMBF, vol.34, pp.19-34, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01161487
