Channel polarization: a method for constructing capacity-achieving codes for symmetric binaryinput memoryless channels, IEEE Transactions on Information Theory (TIT), vol.55, pp.3051-3073, 2009. ,
List decoding of polar codes, Proceedings of the IEEE International Symposium on Information Theory (ISIT), pp.1-5, 2011. ,
, 3GPP TSG RAN WG1 meeting #87, Chairmans notes of agenda item 7.1.5 Channel coding and modulation, 2016.
Benefits and impact of cloud computing on 5G signal processing: flexible centralization through cloud-ran, IEEE Signal Processing Magazine, vol.31, issue.6, pp.35-44, 2014. ,
Cloud technologies for flexible 5G radio access networks, IEEE Communications Magazine, vol.52, issue.5, pp.68-76, 2014. ,
Cloud ran-the benefits of cirtualization, centralisation and coordination, 2015. ,
5G: A technology vision, 2013. ,
Towards the deployment of a fully centralized cloud-ran architecture, Proceedings of the IEEE International Wireless Communications and Mobile Computing Conference, pp.1055-1060, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01621286
Processing radio access network functions in the cloud: critical issues and modeling, Proceedings of the ACM International Workshop on Mobile Cloud Computing and Services (MCS), pp.36-43, 2015. ,
Fast list decoders for polar codes, IEEE Journal on Selected Areas in Communications (JSAC), vol.34, issue.2, pp.318-328, 2016. ,
, Increasing the speed of polar list decoders, Proceedings of the IEEE International Workshop on Signal Processing Systems (SiPS), pp.1-6, 2014.
On tournament elimination systems, Mathesis Polska, vol.7, pp.154-160, 1932. ,
How to construct polar codes, IEEE Transactions on Information Theory (TIT), vol.59, issue.10, pp.6562-6582, 2013. ,
Efficient design and decoding of polar codes, IEEE Transactions on Communications, vol.60, issue.11, pp.3221-3227, 2012. ,
Multi-Gb/s software decoding of polar codes, IEEE Transactions on Signal Processing (TSP), vol.63, issue.2, pp.349-359, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01286280
Fast polar decoders: algorithm and implementation, IEEE Journal on Selected Areas in Communications (JSAC), vol.32, issue.5, pp.946-957, 2014. ,
LLR-based successive cancellation list decoding of polar codes, IEEE Transactions on Signal Processing (TSP), vol.63, issue.19, pp.5165-5179, 2015. ,
A simplified successive-cancellation decoder for polar codes, IEEE Communications Letters, vol.15, issue.12, pp.1378-1380, 2011. ,
An adaptive successive cancellation list decoder for polar codes with cyclic redundancy check, IEEE Communications Letters, vol.16, issue.12, pp.2044-2047, 2012. ,
Mersenne twister: a 623-dimensionally equidistributed uniform pseudorandom number generator, ACM Transactions on Modeling and Computer Simulation (TOMACS), vol.8, issue.1, pp.3-30, 1998. ,
A note on the generation of random normal deviates, The annals of mathematical statistics, vol.29, pp.610-611, 1958. ,
4G: LTE/LTEadvanced for mobile broadband, 2013. ,
A novel puncturing scheme for polar codes, IEEE Communications Letters, vol.18, issue.12, pp.2081-2084, 2014. ,
Beyond turbo codes: rate-compatible punctured polar codes, Proceedings of the IEEE International Conference on Communications (ICC), pp.3423-3427, 2013. ,
Shortened polar codes, IEEE Transactions on Information Theory (TIT), vol.61, issue.9, pp.4852-4865, 2015. ,
, Cyclic redundancy check, pp.2017-2020
CRC code design for list decoding of polar codes, IEEE Communications Letters, vol.21, issue.6, pp.1229-1232, 2017. ,
A reduced latency list decoding algorithm for polar codes, Proceedings of the IEEE International Workshop on Signal Processing Systems (SiPS), pp.1-6, 2014. ,
Low-latency software polar decoders, Springer Journal of Signal Processing Systems, pp.31-53, 2016. ,
An efficient, portable and generic library for successive cancellation decoding of polar codes, Proceedings of the Springer International Workshop on Languages and Compilers for Parallel Computing, pp.303-317, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01203105
Energy consumption analysis of software polar decoders on low power processors, Proceedings of the IEEE European Signal Processing Conference, pp.642-646, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01363975
Class of algorithms for decoding block codes with channel measurement information, IEEE Transactions on Information Theory (TIT), vol.18, pp.170-182, 1972. ,
The art of computer programming, 1973. ,
Using SIMD registers and instructions to enable instructionlevel parallelism in sorting algorithms, Proceedings of the ACM Symposium on Parallel Algorithms and Architectures, pp.348-357, 2007. ,
Lowlatency software successive cancellation list polar decoder using stage-located copy, Proceedings of the IEEE International Conference on Digital Signal Processing (DSP), 2016. ,
A semi-parallel successive-cancellation decoder for polar codes, IEEE Transactions on Signal Processing (TSP), vol.61, issue.2, pp.289-299, 2013. ,
