Efficient string matching: An aid to bibliographic search, Communications of the ACM, vol.18, issue.6, pp.333-340, 1975. ,
, Faster approximate string matching, Algorithmica, vol.23, pp.127-158, 1999.
Twenty years of bit-parallelism in string matching, Prague Stringology Club, pp.72-101, 2012. ,
, Fundamentals of Network Forensics: A Research Perspective, 2016.
, NR-grep: A fast and flexible pattern-matching tool, Software-Practice and Experience, vol.31, pp.1265-1312, 2001.
A bit-parallel approach to suffix automata: Fast extended string matching, Proceedings of the Annual Symposium on Combinatorial Pattern Matching, pp.14-33, 1998. ,
Snort-Lightweight intrusion detection for networks, Proceedings of the Thirteenth USENIX Conference on System Administration, pp.229-238, 1999. ,
The Snort Project (manual-snort-org.s3-website-us-east-1.ama zonaws, vol.9, p.2017 ,
Time Warps, String Edits and Macromolecules: The Theory and Practice of Sequence Comparison, 1983. ,
Approximate search with constraints on indels with application in spam filtering, Proceedings of the Norwegian Information Security Conference, pp.22-33, 2015. ,
Constrained row-based bitparallel search in intrusion detection, Proceedings of the Norwegian Information Security Conference, pp.68-79, 2016. ,
A constrained approximate search algorithm for detecting similar attack patterns, pp.163-176, 2018. ,
Fast text searching: Allowing errors, Communications of the ACM, vol.35, issue.10, pp.83-91, 1992. ,
