Measuring Evidential Weight in Digital Forensic Investigations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Richard Overill
  • Fonction : Auteur
  • PersonId : 1041898
This chapter describes a method for obtaining a quantitative measure of the relative weight of each individual item of evidence in a digital forensic investigation using a Bayesian network. The resulting evidential weights can then be used to determine a near-optimal, cost-effective triage scheme for the investigation in question.
472401_1_En_1_Chapter.pdf (206.08 Ko) Télécharger le fichier
hal-01988848 , version 1 (22-01-2019)
Paternité
Richard Overill, Kam-Pui Chow. Measuring Evidential Weight in Digital Forensic Investigations. 14th IFIP International Conference on Digital Forensics (DigitalForensics), Jan 2018, New Delhi, India. pp.3-10, ⟨10.1007/978-3-319-99277-8_1⟩. ⟨hal-01988848⟩
81 Consultations
181 Téléchargements
