A fast iterative shrinkagethresholding algorithm for linear inverse problems, SIAM journal on imaging sciences, vol.2, issue.1, pp.183-202, 2009. ,
Distributed optimization and statistical learning via the alternating direction method of multipliers, Trends Machine Learning, vol.3, pp.1-122, 2011. ,
Enhancing sparsity by reweighted l1 minimization, Journal of Fourier analysis and applications, 2008. ,
On the convergence of the iterates of "fista, Journal of Optimization Theory and Applications, issue.166, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01060130
A first-order primal-dual algorithm for convex problems with applications to imaging, Journal of Mathematical Imaging and Vision, vol.40, issue.1, pp.120-145, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00490826
On the ergodic convergence rates of a first-order primal-dual algorithm, Math. Program, vol.159, issue.1-2, pp.253-287, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01151629
Nested iterative algorithms for convex constrained image recovery problems. SIAM, pp.730-762, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00621932
Proximal splitting methods in signal processing. In Fixed-point algorithms for inverse problems in science and engineering, pp.185-212, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00643807
Signal recovery by proximal forward-backward splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00017649
Fast projection onto the simplex and the l1 ball, Mathematical Programming Series A, vol.158, issue.1, pp.575-585, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01056171
Discriminative cluster analysis, ICML 06 Proceedings of the 23rd international conference on Machine learning, 2006. ,
Adaptive dimension reduction using discriminant analysis and k-means clustering, Proceedings of the 24th International Conference on Machine Learning, pp.521-528, 2007. ,
Compressed sensing, IEEE Trans. Inf. Theor, vol.52, issue.4, pp.1289-1306, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00369486
Optimally sparse representation in general (nonorthogonal) dictionaries vià1 minimization, Proceedings of the National Academy of Sciences, vol.100, issue.5, pp.2197-2202, 2003. ,
Efficient projections onto the l 1-ball for learning in high dimensions, Proceedings of the 25th international conference on Machine learning, pp.272-279, 2008. ,
A general framework for a class of first order primal-dual algorithms for convex optimization in imaging science, SIAM J. Imaging Sci, vol.3, issue.4, pp.1015-1046, 2010. ,
Method of the year 2013: Methods to sequence the dna and rna of single cells are poised to transform many areas of biology and medicine, Nature Methods, vol.11, 2014. ,
Robust discriminative clustering with sparse regularizers, Journal of Machine Learning Research, vol.18, issue.80, pp.1-50, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01357666
Regularization path for generalized linear models via coordinate descent, Journal of Statistical Software, vol.33, pp.1-122, 2010. ,
Support vector machine classification and validation of cancer tissue samples using microarray expression data, Bioinformatics, vol.16, issue.10, pp.906-914, 2000. ,
Gene selection for cancer classification using support vector machines, Machine learning, vol.46, issue.1-3, pp.389-422, 2002. ,
Feature extraction, foundations and applications. studies in fuzziness and soft computing, 2017. ,
The entire regularization path for the support vector machine, Journal of Machine Learning Research, vol.5, pp.1391-1415, 2004. ,
Statistcal learning with sparsity: The lasso and generalizations, 2015. ,
Group lasso with overlap and graph lasso, Proceedings of the 26th International Conference on Machine Learning (ICML09), pp.353-360, 2009. ,
Network-constrained regularization and variable selection for analysis of genomic data, Bioinformatics, vol.24, issue.9, pp.1175-1182, 2008. ,
Feature selection: A data perspective, ACM Computing Surveys, vol.50, 2016. ,
DOI : 10.1145/3136625
URL : http://arxiv.org/pdf/1601.07996
Splitting algorithms for the sum of two nonlinear operators, SIAM Journal on Numerical Analysis, vol.16, issue.6, pp.964-979, 1979. ,
Moreau-yosida regularization for grouped tree structure learning, Advances in Neural Information Processing Systems 23 ,
A robust and efficient doubly regularized metric learning approach, Proceedings of the 12th European Conference on Computer VisionVolume Part IV, ECCV'12, 2012. ,
Complexity analysis of the lasso regularization path, Proceedings of the 29th International Conference on Machine Learning (ICML-12), pp.353-360, 2012. ,
Proximité et dualité dans un espace hilbertien, Bull. Soc.Math. France, vol.93, pp.273-299, 1965. ,
DOI : 10.24033/bsmf.1625
URL : http://www.numdam.org/article/BSMF_1965__93__273_0.pdf
Solving structured sparsity regularization with proximal methods, Machine Learning and Knowledge Discovery in Databases, pp.418-433, 2010. ,
Feature selection, l 1 vs. l 2 regularization, and rotational invariance, Proceedings of the twenty-first international conference on Machine learning, p.78, 2004. ,
Efficient and robust feature selection via joint l2,1-norms minimization, Advances in Neural Information Processing Systems, vol.23, pp.1813-1821, 2010. ,
Primal-dual decomposition by operator splitting and applications to image deblurring, SIAM, vol.7, issue.3, pp.1724-1754, 2014. ,
An algorithm for minimizing the mumford-shah functional, IEEE 12th International Conference on, pp.1133-1140, 2009. ,
Hubs in space: Popular nearest neighbors in high-dimensional data, Journal of Machine Learning Research, vol.11, pp.2487-2531, 2010. ,
Single-cell transcriptomics of 20 mouse organs creates a tabula muris, Nature, vol.562, issue.7727, pp.367-372, 2018. ,
A sparse-group lasso, Journal of Computational and Graphical Statistics, vol.22, issue.2, pp.231-245, 2013. ,
Scalable nonconvex inexact proximal splitting, Advances in Neural Information Processing Systems 25: 26th Annual Conference on Neural Information Processing Systems, pp.539-547, 2012. ,
Regression shrinkage and selection via the lasso, Journal of the Royal Statistical Society. Series B (Methodological), pp.267-288, 1996. ,
Acceleration of the PDHGM on partially strongly convex functions, J. Math. Imaging Vision, vol.59, issue.3, pp.394-414, 2017. ,
A framework for feature selection in clustering, Journal of the American Statistical Association, vol.105, issue.490, pp.713-726, 2010. ,
Model selection and estimation in regression with grouped variables, J. R. Stat. Soc. Ser. B, vol.68, issue.1, pp.49-67 ,
Regularization and variable selection via the elastic net, Journal of the Royal Statistical Society, Series B, vol.67, pp.301-320, 2005. ,
Sparse principal component analysis, Journal of computational and graphical statistics, vol.15, issue.2, pp.265-286, 2006. ,
