Journal articles
Diagonal Acceleration for Covariance Matrix Adaptation Evolution Strategies
Youhei Akimoto 1 Nikolaus Hansen 2, 3
2 RANDOPT - Randomized Optimisation
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : We introduce an acceleration for covariance matrix adaptation evolution strategies (CMA-ES) by means of adaptive diagonal decoding (dd-CMA). This diagonal acceleration endows the default CMA-ES with the advantages of separable CMA-ES without inheriting its drawbacks. Technically, we introduce a diagonal matrix $D$ that expresses coordinate-wise variances of the sampling distribution in $DCD$ form. The diagonal matrix can learn a rescaling of the problem in the coordinates within linear number of function evaluations. Diagonal decoding can also exploit separability of the problem, but, crucially, does not compromise the performance on non-separable problems. The latter is accomplished by modulating the learning rate for the diagonal matrix based on the condition number of the underlying correlation matrix. dd-CMA-ES not only combines the advantages of default and separable CMA-ES, but may achieve overadditive speedup: it improves the performance, and even the scaling, of the better of default and separable CMA-ES on classes of non-separable test functions that reflect, arguably, a landscape feature commonly observed in practice. The paper makes two further secondary contributions: we introduce two different approaches to guarantee positive definiteness of the covariance matrix with active CMA, which is valuable in particular with large population size; we revise the default parameter setting in CMA-ES, proposing accelerated settings in particular for large dimension. All our contributions can be viewed as independent improvements of CMA-ES, yet they are also complementary and can be seamlessly combined. In numerical experiments with dd-CMA-ES up to dimension 5120, we observe remarkable improvements over the original covariance matrix adaptation on functions with coordinate-wise ill-conditioning. The improvement is observed also for large population sizes up to about dimension squared.
Complete list of metadatas
Cited literature [39 references]  Display  Hide  Download
https://hal.inria.fr/hal-01995373
Contributor : Nikolaus Hansen <>
Submitted on : Thursday, May 30, 2019 - 4:27:10 PM
Last modification on : Friday, November 27, 2020 - 3:31:14 AM
File
akimoto2019diagonal.pdf
Identifiers
Collections
Citation
Youhei Akimoto, Nikolaus Hansen. Diagonal Acceleration for Covariance Matrix Adaptation Evolution Strategies. Evolutionary Computation, Massachusetts Institute of Technology Press (MIT Press), 2020, 28 (3), pp.405-435. ⟨10.1162/evco_a_00260⟩. ⟨hal-01995373v2⟩
Share
Metrics
Record views
248
Files downloads
985
