Spatio-temporal correlation: theory and applications for wireless sensor networks, Computer Networks: The International Journal of Computer and Telecommunications Networking archive, vol.45, issue.3, p.245259, 2004. ,
Optimal cluster size for wireless sensor networks: An experimental analysis, vol.28, 2010. ,
Performance evaluation of user selection protocols in random networks with energy harvesting and hardware impairments, Advances in Electrical and Electronic Engineering, vol.14, issue.4, pp.372-377, 2016. ,
Two-way relaying networks in green communications for 5G: Optimal throughput and tradeoff between relay distance on power splitting-based and time switching-based relaying SWIPT, AEU-International Journal of Electronics and Communications, vol.70, issue.12, pp.1637-1644, 2016. ,
Genetic algorithms for lifetime elongation of clustered WSN, 2017 IEEE 28th Annual International Symposium on Personal, Indoor, and Mobile Radio Communications (PIMRC), pp.1-7, 2017. ,
Energy efficient K-means clustering-based routing protocol for WSN using optimal packet size, 2018 International Conference on Information Networking (ICOIN), pp.632-635, 2018. ,
Near-optimal node clustering in wireless sensor networks for environment monitoring, Proc. of the 21st Int. Conf. on Advanced Networking and Applications, 2007. ,
CLIQUE: Role-free clustering with Q-learning for Wireless Sensor Networks, Proc. of the 29st Int. Conf. on Distr.Computing (ICDCS), 2009. ,
Intelligent hierarchical cluster-based routing, Proc. of the 29st Int. Works. on Mobility and Scalability in Wireless Sensor Networks (MSWSN), 2006. ,
A Unified Clustering and Communication Protocol for Wireless Sensor Networks, International Journal on Computer Science, 2008. ,
Research on clustering routing algorithm based on K-means++ for WSN, 6th International Conference on Computer Science and Network Technology (ICCSNT), pp.330-333, 2017. ,
A survey on connected dominating set construction algorithm for wireless sensor networks, Inform. Technol.J, 2010. ,
An Introduction with Applications, vol.3, pp.540-60127, 1995. ,
Energy efficient distributed cluster head scheduling scheme for two tiered wireless sensor network, Egyptian Informatics Journal, vol.16, issue.2, pp.167-174, 2015. ,
Energy efficient clustering algorithm for maximizing lifetime of wireless sensor networks, AEU-International Journal of Electronics and Communications, vol.64, issue.4, pp.289-298, 2010. ,
EDDEEC: Enhanced Developed Distributed Energy-efficient Clustering for Heterogeneous Wireless Sensor Networks, Procedia Computer Science, vol.19, pp.914-919, 2013. ,
