An Axiomatization of Information Flow Measures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2019
Quantitative information flow aims to assess and control the leakage of sensitive information by computer systems. A key insight in this area is that no single leakage measure is appropriate in all operational scenarios; as a result, many leakage measures have been proposed, with many different properties. To clarify this complex situation, this paper studies information leakage axiomatically, showing important dependencies among different axioms. It also establishes a completeness result about the g-leakage family, showing that any leakage measure satisfying certain intuitively-reasonable properties can be expressed as a g-leakage.
main.pdf (740.99 Ko) Télécharger le fichier
hal-01995712 , version 1 (11-07-2019)
Mário S. Alvim, Konstantinos Chatzikokolakis, Carroll Morgan, Catuscia Palamidessi, Geoffrey Smith, et al.. An Axiomatization of Information Flow Measures. Theoretical Computer Science, 2019, 777, pp.32-54. ⟨10.1016/j.tcs.2018.10.016⟩. ⟨hal-01995712⟩
235 Consultations
213 Téléchargements
