The Perception of Ultrasonic Square Reductions of Friction with Variable Sharpness and Duration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Haptics (ToH) Année : 2019
The human perception of square ultrasonic modulation of the finger-surface friction was investigated during active tactile exploration by using short frictional cues of varying duration and sharpness. In a first experiment, we asked participants to discriminate the transition time and duration of short square ultrasonic reductions of friction. They proved very sensitive to discriminate millisecond differences in these two parameters with the average psychophysical thresholds being 2.3-2.4 ms for both parameters. A second experiment focused on the perception of square friction reductions with variable transition times and durations. We found that for durations of the stimulation larger than 90 ms, participants often perceived three or four edges when only two stimulations were presented while they consistently felt two edges for signals shorter than 50 ms. A subsequent analysis of the contact forces induced by these ultrasonic stimulations during slow and fast active exploration showed that two identical consecutive ultrasonic pulses can induce significantly different frictional dynamics especially during fast motion of the finger. These results confirm the human sensitivity to transient frictional cues and suggest that the human perception of square reductions of friction can depend on their sharpness and duration as well as on the speed of exploration.
Gueorguiev et al. Sharpness and duration 2019.pdf (2.93 Mo) Télécharger le fichier
hal-01997265 , version 1 (29-01-2019)
David Gueorguiev, Eric Vezzoli, Thomas Sednaoui, Laurent Grisoni, Betty Lemaire-Semail. The Perception of Ultrasonic Square Reductions of Friction with Variable Sharpness and Duration. IEEE Transactions on Haptics (ToH), In press, 14, pp.1-1. ⟨10.1109/TOH.2019.2894412⟩. ⟨hal-01997265⟩
210 Consultations
358 Téléchargements
