Exploring Sustainable HCI Research Dimensions Through the Inclusive Innovation Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Tobias Nyström
  • Fonction : Auteur
  • PersonId : 1042303
When frameworks and design principles for open innovation and open sustainability innovation (OSI) were established in earlier research, their foundations were originated from the expanded concepts of universal design (UD) from human-computer interaction (HCI) in a prescriptive form. This also was the basis of an inclusive innovation framework (IIF) aiming for a sustainable information system design. In this paper the IIF originating from the concept of combining UD and open innovation (OI) in promoting information technology enabling sustainability goals was analyzed together with OI and OSI frameworks. The role of OI in formulating the IIF was thereby strengthened, which in parallel helped recognizing the extended conceptions of sustainable HCI (SHCI) and its future research path through the use of IIF.
472718_1_En_11_Chapter.pdf (175.47 Ko) Télécharger le fichier
hal-02001951 , version 1 (31-01-2019)
Paternité
Tobias Nyström, Moyen Mustaquim. Exploring Sustainable HCI Research Dimensions Through the Inclusive Innovation Framework. 13th IFIP International Conference on Human Choice and Computers (HCC13), Sep 2018, Poznan, Poland. pp.151-165, ⟨10.1007/978-3-319-99605-9_11⟩. ⟨hal-02001951⟩
93 Consultations
107 Téléchargements
