Actualiser l’hérésie au temps de la Réforme. Catholicité, innovations doctrinales et Inquisition dans l’Espagne de la première modernité, 1517-1530 - Archive ouverte HAL Access content directly
Journal Articles Cahiers d’Études des Cultures Ibériques et Latino-américaines Year : 2018
Remodeling heresy during the Reformation. Catholic orthodoxy, doctrinal innovations and Inquisition in Early Modern Spain from 1517 to 1530
Actualizar la herejía en tiempos de la Reforma. Catolicidad, innovaciones doctrinales e Inquisición en la España de la primera modernidad, 1517-1530
When perusing inquisitorial sources from the first third of the XVIth century, the theological objectification mechanism, as regards doctrinal innovations, in the context of Lutheran dissent, proves to be rather convoluted and the legal constraints imposed on inquisitors are obvious. Between 1517 (end of the Fifth Council of Lateran) and 1530 (calling of the Diet of Augsburg), the outlines of orthodoxy were the targets of sharp disagreement. Since it lacked effective canons, the Inquisition progressively shaped jurisprudence, enabling the Tribunal to comprehend the constituting elements of new heresies. The Holy Office monitored the reception of the religious controversy in Spain and assessed its consequences because of the lack of consensus regarding faith. Under preachers’ surveillance, it looked after doctrinal uniformity. By taking legal actions against the alumbrados, the Tribunal of the Inquisition intended to identify the distinctive features of the beginnings of heresy in Spain.
De las fuentes inquisitoriales del primer tercio del siglo XVI se desprende que resultó complejo el proceso de formalización teológica de las innovaciones doctrinales, en un contexto de rebelión luterana, y que fueron tangibles las restricciones jurídicas impuestas a los inquisidores. Entre 1517 –conclusión del concilio de Letrán V– y 1530 –Dieta de Augsburgo– los contornos de la ortodoxia fueron objeto de disenso. A falta de cánones aplicables, fue gradualmente como se elaboró la jurisprudencia con la que la Inquisición concibió los elementos constitutivos de las nuevas herejías. Sin consenso en materia de fe, el Santo Oficio vigiló la recepción en España de las controversias religiosas y evaluó las repercusiones de estas. A través del control de los predicadores, veló por la uniformidad doctrinal. En Toledo, incoando procesos contra los alumbrados, el tribunal se dedicó a determinar los caracteres de la génesis de la herejía en España.
À la lecture des sources inquisitoriales du premier tiers du XVIe siècle, le processus d’objectivation théologique des innovations doctrinales s’avère complexe, sur fond de rébellion luthérienne, et les contraintes juridiques s’imposant aux magistrats sont tangibles. Entre 1517 – date de clôture du concile du Latran V – et 1530 – convocation de la Diète d’Augsbourg – les contours de l’orthodoxie font l’objet de dissentiment. À défaut de canons applicables, c’est graduellement que l’Inquisition façonne une jurisprudence lui permettant d’appréhender les éléments constitutifs des nouvelles hérésies. En l’absence de consensus en matière de foi, le Saint-Office surveille la réception en Espagne de la controverse religieuse et en évalue les répercussions. À travers le contrôle des prédicateurs, il entend maintenir l’uniformité doctrinale. À Tolède, en engageant des poursuites contre les alumbrados, le tribunal s’attache à déterminer les caractères de la genèse de l’hérésie en Espagne.
Not file
Dates and versions
hal-02007225 , version 1 (05-02-2019)
Identifiers
Cite
David Kahn. Actualiser l’hérésie au temps de la Réforme. Catholicité, innovations doctrinales et Inquisition dans l’Espagne de la première modernité, 1517-1530. Cahiers d’Études des Cultures Ibériques et Latino-américaines , 2018, La fabrique de l’hérésie. L’hérétique et ses représentations à l’époque moderne : Espagne, Portugal, Amérique (XVIe-XVIIe s.), 4, ⟨10.21409/c4_1⟩. ⟨hal-02007225⟩
63 View
0 Download
Share
