Psychophysical Comparison of the Auditory and Vibrotactile Perception-Absolute Sensitivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sebastian Merchel
  • Fonction : Auteur
  • PersonId : 1042466
Mehmet Ercan Altinsoy
  • Fonction : Auteur
  • PersonId : 1042467
In this paper, the psychophysical abilities and limitations of the auditory and vibrotactile modality will be discussed. A direct comparison reveals similarities and differences. The knowledge of those is important for the design of audio-haptic systems, multimodal music applications or perceptually optimized human-machine interfaces. Literature data and own results for psychophysical characteristics are discussed. This paper focuses on the absolute perception thresholds of both modalities. The main factors which influence these thresholds are discussed: age, energy integration, masking and adaptation.
paper1.pdf (396.52 Ko) Télécharger le fichier
hal-02007390 , version 1 (05-02-2019)
  • HAL Id : hal-02007390 , version 1
Sebastian Merchel, Mehmet Ercan Altinsoy. Psychophysical Comparison of the Auditory and Vibrotactile Perception-Absolute Sensitivity. International Workshop on Haptic and Audio Interaction Design - HAID2019, Mar 2019, Lille, France. ⟨hal-02007390⟩
Collections
HAID2019
221 Consultations
489 Téléchargements
