An improved uncertainty propagation method for robust i-vector based speaker recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The performance of automatic speaker recognition systems degrades when facing distorted speech data containing additive noise and/or reverberation. Statistical uncertainty propagation has been introduced as a promising paradigm to address this challenge. So far, different uncertainty propagation methods have been proposed to compensate noise and reverberation in i-vectors in the context of speaker recognition. They have achieved promising results on small datasets such as YOHO and Wall Street Journal, but little or no improvement on the larger, highly variable NIST Speaker Recognition Evaluation (SRE) corpus. In this paper, we propose a complete uncertainty propagation method, whereby we model the effect of uncertainty both in the computation of unbiased Baum-Welch statistics and in the derivation of the posterior expectation of the i-vector. We conduct experiments on the NIST-SRE corpus mixed with real domestic noise and reverberation from the CHiME-2 corpus and preprocessed by multichannel speech enhancement. The proposed method improves the equal error rate (EER) by 4% relative compared to a conventional i-vector based speaker verification baseline. This is to be compared with previous methods which degrade performance.
ribas_ICASSP19.pdf (68.89 Ko) Télécharger le fichier
hal-02010199 , version 1 (07-02-2019)
hal-02010199 , version 2 (19-02-2019)
Dayana Ribas, Emmanuel Vincent. An improved uncertainty propagation method for robust i-vector based speaker recognition. 44th International Conference on Acoustics, Speech, and Signal Processing (ICASSP 2019), May 2019, Brighton, United Kingdom. ⟨hal-02010199v1⟩
110 Consultations
178 Téléchargements
