Sparse analysis for mesoscale convective systems tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing: Image Communication Année : 2020
In this paper, we study the tracking of de-formable shapes in sequences of images. Our target application is the tracking of clouds in satellite image. We propose to use a recent state-of-the-art method for off-the-grid sparse analysis to describe clouds in image as mixtures of 2D atoms. Then, we introduce an algorithm to handle the tracking with its specificities: apparition or disappearance of objects, merging, and splitting. This method provides similar numerical outputs as the recent state-of-the-art alternatives, while being more flexible, and providing additional information on, e.g., cloud surface brightness.
spic-samcst-hal.pdf (4.03 Mo) Télécharger le fichier
hal-02010436 , version 1 (07-02-2019)
hal-02010436 , version 2 (16-09-2020)
Jean-Baptiste Courbot, Vincent Duval, Bernard Legras. Sparse analysis for mesoscale convective systems tracking. Signal Processing: Image Communication, 2020, 85, pp.115854. ⟨10.1016/j.image.2020.115854⟩. ⟨hal-02010436v2⟩
328 Consultations
208 Téléchargements
