Dwell-time control sets and applications to the stability analysis of linear switched systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2020
We propose an extension of the theory of control sets to the case of inputs satisfying a dwell-time constraint. Although the class of such inputs is not closed under concatenation, we propose a suitably modified definition of control sets that allows to recover some important properties known in the concatenable case. In particular we apply the control set construction to dwell-time linear switched systems, characterizing their maximal Lyapunov exponent looking only at trajectories whose angular component is periodic. We also use such a construction to characterize supports of invariant measures for random switched systems with dwell-time constraints.
notes.pdf (470.35 Ko) Télécharger le fichier
hal-02012606 , version 1 (08-02-2019)
Francesco Boarotto, Mario Sigalotti. Dwell-time control sets and applications to the stability analysis of linear switched systems. Journal of Differential Equations, 2020, 268, pp.1345-1378. ⟨10.1016/j.jde.2019.08.049⟩. ⟨hal-02012606⟩
214 Consultations
125 Téléchargements
