Fast audio-haptic prototyping with mass-interaction physics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
James Leonard
  • Fonction : Auteur
  • PersonId : 961302
Jerome Villeneuve
  • Fonction : Auteur
  • PersonId : 956285
This paper presents ongoing work on the topic of physical modelling and force-feedback interaction. Specifically, it proposes a frame- work for rapidly prototyping virtual objects and scenes by means of mass-interaction models, and coupling the user and these objects via an affordable multi-DoF haptic device. The modelled objects can be computed at the rate of the haptic loop, but can also operate at a higher audio-rate, producing sound. The open-source design and overall simplicity of the proposed system makes it an interesting solution for introducing both physical simulations and force-feedback interaction, and also for applications in artistic creation. This first implementation prefigures current work conducted on the develop- ment of modular open-source mass-interaction physics tools for the design of haptic and multisensory applications.
paper6.pdf (936.04 Ko) Télécharger le fichier
hal-02015740 , version 1 (12-02-2019)
hal-02015740 , version 2 (25-02-2019)
  • HAL Id : hal-02015740 , version 2
James Leonard, Jerome Villeneuve. Fast audio-haptic prototyping with mass-interaction physics. HAID 2019 - International Workshop on Haptic and Audio Interaction Design, Mar 2019, Lille, France. ⟨hal-02015740v2⟩
317 Consultations
340 Téléchargements
