Large scale in transit computation of quantiles for ensemble runs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
The classical approach for quantiles computation requires availability of the full sample before ranking it. In uncertainty quantification of numerical simulation models, this approach is not suitable at exascale as large ensembles of simulation runs would need to gather a prohibitively large amount of data. This problem is solved thanks to an on-the-fly and iterative approach based on the Robbins-Monro algorithm. This approach relies on Melissa, a file avoiding, adaptive, fault-tolerant and elastic framework. On a validation case producing 11 TB of data, which consists in 3000 fluid dynamics parallel simulations on a 6M cell mesh, it allows on-line computation of spatio-temporal maps of percentiles.
paper.pdf (2.14 Mo) Télécharger le fichier
hal-02016828 , version 1 (12-02-2019)
hal-02016828 , version 2 (10-05-2019)
Alejandro Ribes, Théophile Terraz, Bertrand Iooss, Yvan Fournier, Bruno Raffin. Large scale in transit computation of quantiles for ensemble runs. [Research Report] EDF R&D. 2019. ⟨hal-02016828v2⟩
344 Consultations
313 Téléchargements
