The Orthogonal Colouring Game - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
We introduce the Orthogonal Colouring Game, in which two players alternately colour vertices (from a choice of m ∈ N colours) of a pair of isomorphic graphs while respecting the properness and the orthogonality of the colouring. Each player aims to maximise her score, which is the number of coloured vertices in the copy of the graph she owns. The main result of this paper is that the second player has a strategy to force a draw in this game for any m ∈ N for graphs that admit a strictly matched involution. An involution σ of a graph G is strictly matched if its fixed point set induces a clique and any non-fixed point v ∈ V (G) is connected with its image σ(v) by an edge. We give a structural characterisation of graphs admitting a strictly matched involution and bounds for the number of such graphs. Examples of such graphs are the graphs associated with Latin squares and sudoku squares.
final76orthogonalGraphColoringGame.pdf (417.5 Ko) Télécharger le fichier
hal-02017462 , version 1 (13-02-2019)
hal-02017462 , version 2 (01-03-2019)
hal-02017462 , version 3 (04-03-2019)
hal-02017462 , version 4 (16-04-2019)
  • HAL Id : hal-02017462 , version 3
Stephan Dominique Andres, Melissa Huggan, Fionn Mc Inerney, Richard J Nowakowski. The Orthogonal Colouring Game. [Research Report] Inria - Sophia Antipolis. 2019. ⟨hal-02017462v3⟩
Collections
LARA
281 Consultations
402 Téléchargements
