Homogenization of the Poisson equation in a non-periodically perforated domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 2021
We study the Poisson equation in a perforated domain with homogeneous Dirichlet boundary conditions. The size of the perforations is denoted by ε > 0, and is proportional to the distance between neighbouring perforations. In the periodic case, the homogenized problem (obtained in the limit ε → 0) is well understood (see [21]). We extend these results to a non-periodic case which is defined as a localized deformation of the periodic setting. We propose geometric assumptions that make precise this setting, and we prove results which extend those of the periodic case: existence of a corrector, convergence to the homogenized problem, and two-scale expansion.
article2.pdf (529.5 Ko) Télécharger le fichier
hal-02019504 , version 1 (14-02-2019)
hal-02019504 , version 2 (28-09-2020)
Xavier Blanc, Sylvain Wolf. Homogenization of the Poisson equation in a non-periodically perforated domain. Asymptotic Analysis, 2021, ⟨10.3233/ASY-201667⟩. ⟨hal-02019504v2⟩
343 Consultations
309 Téléchargements
