Wildsensing: Design and deployment of a sustainable sensor network for wildlife monitoring, ACM Transactions on Sensor Networks ,
Evaluating the accuracy of vehicle tracking data obtained from unmanned aerial vehicles, unmanned Aerial Vehicles and Remote Sensing, vol.5, pp.136-151, 2016. ,
Survey on unmanned aerial vehicle networks for civil applications: A communications viewpoint, IEEE Communications Surveys Tutorials, vol.18, issue.4, pp.2624-2661, 2016. ,
Ad hoc network for emergency rescue system based on unmanned aerial vehicles, Network Protocols and Algorithms, vol.7, issue.4, pp.72-89, 2015. ,
Modeling air-to-ground path loss for low altitude platforms in urban environments, 2014 IEEE Global Communications Conference, pp.2898-2904, 2014. ,
Efficient deployment of multiple unmanned aerial vehicles for optimal wireless coverage, IEEE Comm. Lett, vol.20, issue.8, pp.1647-1650, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01777917
Graph-theoretic connectivity control of mobile robot networks, Proceedings of the IEEE, vol.99, issue.9, pp.1525-1540, 2011. ,
, Connectivity versus area coverage in unmanned aerial vehicle networks, pp.719-723, 2012.
Efficient deployment of connected unmanned aerial vehicles for optimal target coverage, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01575618
Viable path planning for data collection robots in a sensing field with obstacles, Computer Communications, vol.111, pp.84-96, 2017. ,
Guerriero, Optimal drone placement and cost-efficient target coverage, Journal of Network and Computer Applications, vol.75, pp.16-31, 2016. ,
Bi-objective data gathering path planning for vehicles with bounded curvature, Computers & Operations Research, vol.84, pp.195-204, 2017. ,
Charge me if you can: Charging path optimization and scheduling in mobile networks, Proceedings of the 17th ACM International Symposium on Mobile Ad Hoc Networking and Computing, MobiHoc '16, pp.101-110, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01418461
Data mules: modeling and analysis of a three-tier architecture for sparse sensor networks, sensor Network Protocols and Applications, vol.1, pp.3-9, 2003. ,
A line-based data dissemination protocol for wireless sensor networks with mobile sink, Proceedings of IEEE International Conference on Communications, pp.2201-2205, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00384139
Energy efficient schemes for wireless sensor networks with multiple mobile base stations, Proceedings of the Global Telecommunications Conference, 2003. GLOBECOM '03, pp.377-381, 2003. ,
Moving multiple sinks through wireless sensor networks for lifetime maximization, IEEE 5th International Conference on Mobile Adhoc and Sensor Systems, pp.523-526, 2008. ,
Joint sink mobility and routing to maximize the lifetime of wireless sensor networks: The case of constrained mobility, IEEE/ACM Trans. Netw, vol.18, issue.3, pp.871-884, 2010. ,
Smooth path construction for data mule tours in wireless sensor networks, 2012 IEEE Global Communications Conference, GLOBECOM 2012, pp.86-92, 2012. ,
Connectivity preservation and coverage schemes for wireless sensor networks, IEEE Trans. Automat. Contr, vol.56, issue.10, pp.2418-2428, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00589806
Performance of mobile networks with uavs: Can flying base stations substitute ultra-dense small cells?, 2017. ,
Spread and shrink: Point of interest discovery and coverage with mobile wireless sensors, Journal of Parallel and Distributed Computing, vol.102, pp.16-27, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01406492
On the dubins traveling salesman problem, IEEE Trans. Automat. Contr, vol.57, issue.1, pp.265-270, 2012. ,
Optimizing cascaded chains of unmanned aircraft acting as communication relays, IEEE JSAC, vol.30, issue.5, pp.883-898, 2012. ,
A progressive approach to reducing data collection latency in wireless sensor networks with mobile elements, IEEE Trans. Mob. Comput, vol.12, issue.7, pp.1308-1320, 2013. ,
Coverage-based node placement optimization in wireless sensor network with linear topology, 2016. ,
Optimal positioning of flying relays for wireless networks: A los map approach, IEEE ICC, 2017. ,
Optimal uav coordination for target tracking using dynamic programming, pp.4541-4546, 2010. ,
Node placement for connected coverage in sensor networks, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00466114
Modelling the mobile target covering problem using flying drones, Optimization Letters, vol.10, issue.5, pp.1021-1052, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01187118
Optimization of mobile sensor coverage with uavs, IEEE INFOCOM 2018-IEEE Conference on Computer Communications Workshops, INFOCOM Workshops, pp.622-627, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01850442
Mobile element scheduling for efficient data collection in wireless sensor networks with dynamic deadlines, 25th IEEE International Real-Time Systems Symposium, pp.296-305, 2004. ,
Energy-aware set-covering approaches for approximate data collection in wireless sensor networks, IEEE Transactions on Knowledge and Data Engineering, vol.24, issue.11, 1993. ,
Dynamic vehicle routing for robotic systems, IEEE proceedings, vol.99, issue.9, pp.1482-1504, 2011. ,
Multirobot patrolling in wireless sensor network using bounded cycle coverage, 2016. ,
The dynamic set covering prblem, Applied Mathematical Modelling, vol.6, issue.1, pp.2-6, 1982. ,
Comprehensive survey on dynamic graph models, IJACSA, vol.7, issue.2, pp.573-582, 2016. ,
Efficient Deployment of Connected Unmanned Aerial Vehicles for Optimal Target Coverage, 2017. ,
