Pathological Cluster Identification by Unsupervised Analysis in 3,822 UK Biobank Cardiac MRIs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Cardiovascular Medicine Année : 2020
We perform unsupervised analysis of image-derived shape and motion features extracted from 3,822 cardiac Magnetic resonance imaging (MRIs) of the UK Biobank. First, with a feature extraction method previously published based on deep learning models, we extract from each case 9 feature values characterizing both the cardiac shape and motion. Second, a feature selection is performed to remove highly correlated feature pairs. Third, clustering is carried out using a Gaussian mixture model on the selected features. After analysis, we identify 2 small clusters that probably correspond to 2 pathological categories. Further confirmation using a trained classification model and dimensionality reduction tools is carried out to support this finding. Moreover, we examine the differences between the other large clusters and compare our measures with the ground truth.
1902.05811.pdf (805.94 Ko) Télécharger le fichier
hal-02043380 , version 1 (21-02-2019)
Qiao Zheng, Hervé Delingette, Kenneth Fung, Steffen E Petersen, Nicholas Ayache. Pathological Cluster Identification by Unsupervised Analysis in 3,822 UK Biobank Cardiac MRIs. Frontiers in Cardiovascular Medicine, 2020, 7, pp.164. ⟨10.3389/fcvm.2020.539788⟩. ⟨hal-02043380⟩
89 Consultations
229 Téléchargements
