Emergence of homogamy in a two-loci stochastic population model
This article deals with the emergence of a specific mating preference pattern called homogamy in a population. Individuals are characterized by their genotype at two haploid loci, and the population dynamics is modelled by a non-linear birth-and-death process. The first locus codes for a phenotype, while the second locus codes for homogamy defined with respect to the first locus: two individuals are more (resp. less) likely to reproduce with each other if they carry the same (resp. a different) trait at the first locus. Initial resident individuals do not feature homogamy, and we are interested in the probability and time of invasion of a mutant presenting this characteristic under a large population assumption. To this aim, we study the trajectory of the birth-and-death process during three phases: growth of the mutant, coexistence of the two types, and extinction of the resident. We couple the birth-and-death process with simpler processes, like branching processes or dynamical systems, and study the latter ones in order to control the trajectory and duration of each phase.
