New interface
Reports (Technical report)
Clean up atomics
Jens Gustedt 1
1 CAMUS - Compilation pour les Architectures MUlti-coeurS
Inria Nancy - Grand Est, ICube - Laboratoire des sciences de l'ingénieur, de l'informatique et de l'imagerie
Abstract : Whereas its intent is clear, the text in the C standard that concerns atomics has several consistency problems. There are contradictions and the standard vocabulary is not always applied correctly. This paper attempts to solve these consistency problems, and to provide a path to a straighter and easier to use and to implement specification. Even though individually the identified flaws are simple to repair, all together they form a relatively large batch of changes (spelled out in an appendix).-This is a follow-up of N1955 that resulted from many discussions on the WG14 reflector or elsewhere. In particular, it integrates suggestions by Robert Seacord, Richard Smith, Aaron Ballman, and probably many more.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-02046430
Contributor : Jens Gustedt Connect in order to contact the contributor
Submitted on : Friday, February 22, 2019 - 3:48:32 PM
Last modification on : Thursday, October 27, 2022 - 4:12:34 AM
Long-term archiving on: : Thursday, May 23, 2019 - 3:04:12 PM
File
n2329+appendix.pdf
Identifiers
  • HAL Id : hal-02046430, version 1
Citation
Jens Gustedt. Clean up atomics. [Technical Report] N2329, ISO JCT1/SC22/WG14. 2018. ⟨hal-02046430⟩
Share
Metrics
Record views
54
Files downloads
48
