Automatic benchmark profiling through advanced workflow-based trace analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Software: Practice and Experience Année : 2018
Benchmarking has proven to be crucial for the investigation of the behavior and performances of a system. However, the choice of relevant benchmarks still remains a challenge. To help the process of comparing and choosing among benchmarks, we propose a solution for automatic benchmark profiling. It computes unified benchmark profiles reflecting benchmarks' duration, function repartition, stability, CPU efficiency, parallelization, and memory usage. Our approach identifies the needed system information for profile computation and collects it from execution traces captured without benchmark code modifications. It structures profile computation as a reproducible workflow for automatic trace analysis, which efficiently manages important trace volumes. In this paper, we report on the design and the implementation of our approach, which involves the collection and analysis of about 500 GB of trace data coming from 2 different platforms (an x86 desktop machine and the Juno SoC board). The computed benchmark profiles provide valuable insights about the benchmarks' behavior and help compare different benchmarks on the same platform as well as the behavior of the same benchmark on different platforms.
spedoc.pdf (699.73 Ko) Télécharger le fichier
hal-02047273 , version 1 (06-03-2019)
Alexis Martin, Vania Marangozova-Martin. Automatic benchmark profiling through advanced workflow-based trace analysis. Software: Practice and Experience, 2018, 48 (6), pp.1195-1217. ⟨10.1002/spe.2570⟩. ⟨hal-02047273⟩
91 Consultations
674 Téléchargements
