Random polytopes and the wet part for arbitrary probability distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
We examine how the measure and the number of vertices of the convex hull of a random sample of $n$ points from an arbitrary probability measure in $\mathbf{R}^d$ relates to the wet part of that measure. This extends classical results for the uniform distribution from a convex set [B\'ar\'any and Larman 1988]. The lower bound of B\'ar\'any and Larman continues to hold in the general setting, but the upper bound must be relaxed by a factor of $\log n$. We show by an example that this is tight.
hal-02050632 , version 1 (27-02-2019)
Imre Bárány, Matthieu Fradelizi, Xavier Goaoc, Alfredo Hubard, Günter Rote. Random polytopes and the wet part for arbitrary probability distributions. [Research Report] Rényi Institute of Mathematics; University College London; Université Paris-Est; Université de Lorraine; Freie Universität Berlin. 2019. ⟨hal-02050632⟩
182 Consultations
0 Téléchargements
