A New Wireless Communication Paradigm through Software-controlled Metasurfaces, IEEE Communications Magazine, vol.56, issue.9, pp.162-169, 2018. ,
Using any Surface to Realize a New Paradigm for Wireless Communications, Communications of the ACM, vol.61, issue.11, pp.30-33, 2018. ,
Metamaterials and Metasurfaces for Sensor Applications, Sensors, vol.79, issue.1726, 2017. ,
From metamaterials to metadevices, Nature Materials, vol.11, pp.917-924, 2012. ,
DOI : 10.1038/nmat3431
Ultrathin and multicolour optical cavities with embedded metasurfaces, Nature Communications, vol.9, issue.2673, 2018. ,
A Design for Improving the Sensitivity of a Mach-Zehnder Interferometer to Chemical and Biological Measurands, Sens. Actuators B, vol.81, pp.254-258, 2002. ,
Optical sensing by optimized silicon slot waveguides, Optics Express, vol.15, pp.4977-4993, 2007. ,
An integrated optical Bragg reflector used as a chemo-optical sensor, Pure Appl. Opt, vol.7, pp.23-26, 1998. ,
Waveguide metatronics: Lumped circuitry based on structural dispersion, Science Advances, vol.12, issue.6, 2016. ,
Terahertz magnetic response from artificial materials, Science, vol.303, pp.1494-1496, 2004. ,
Metamaterials and plasmonics: From nanoparticles to nanoantenna arrays, metasurfaces, and metamaterials, Chin. Phys. B, vol.23, 2014. ,
Metasurface holograms for visible light, Nat. Commun, vol.61, issue.11, pp.30-33, 2018. ,
Surface Wave Cloak from Graded Refractive Index Nanocomposites, Scientific Reports, vol.6, issue.29363, 2016. ,
Advanced engineering electromagnetics, 2012. ,
Metamaterial-based Sensor Design working in Infrared Frequency Range, Progress In Electromagnetics Research, vol.34, pp.205-223, 2011. ,
Analysis of the Chirality Effects on the Capacity of Wireless Communication Systems in the THz band, IEEE Transactions on Wireless Communications, vol.16, issue.12, pp.7848-7858, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01589268
