Torque-Based Balancing for a Humanoid Robot Performing High-Force Interaction Tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2019
Balancing is a critical feature for a robot interacting with an unstructured environment. The balancing control should account for unknown perturbation forces that might destabilize the robot when performing the intended tasks. In the case of humanoid robots this challenge is higher due to the inherent difficulties of balancing a robot on two legs, resulting in a rather small footprint. Approaches for enabling a good balancing behavior on humanoid robots traditionally rely on whole-body balancing approaches. This paper extends a passivity-based whole-body balancing framework to guarantee the equilibrium of a humanoid robot while performing different interaction tasks where the (high) task forces acting on the robot are difficult to foresee. Instead of controlling the center of mass, the proposed controller directly uses information from the Gravito-Inertial Wrench Cone to guarantee the feasibility of the balancing forces. The performance of the approach is validated in a number of successful experimental tests.
18-1060_03_MS.pdf (1.07 Mo) Télécharger le fichier
hal-02051454 , version 1 (27-02-2019)
Firas Abi-Farraj, Bernd Henze, Christian Ott, Paolo Robuffo Giordano, Máximo A Roa. Torque-Based Balancing for a Humanoid Robot Performing High-Force Interaction Tasks. IEEE Robotics and Automation Letters, 2019, 4 (2), pp.2023-2030. ⟨10.1109/LRA.2019.2898041⟩. ⟨hal-02051454⟩
195 Consultations
631 Téléchargements
