A policy-blending formalism for shared control, Int. J. Rob. Res, vol.32, issue.7, pp.790-805, 2013. ,
Task-priority based redundancy control of robot manipulators, Int. J. Rob. Res, vol.6, issue.2, pp.3-15, 1987. ,
Task-priority formulations for the kinematic control of highly redundant articulated structures, IEEE/RSJ Int. Conf. Intell. Rob. Sys, vol.1, pp.323-329, 1998. ,
Stability analysis for prioritized closed-loop inverse kinematic algorithms for redundant robotic systems, IEEE Trans. Robot, vol.25, issue.5, pp.985-994, 2009. ,
A unified approach for motion and force control of robot manipulators: The operational space formulation, IEEE J. Robot. Autom, vol.3, issue.1, pp.43-53, 1987. ,
Bilateral telemanipulation with time delays: a two-layer approach combining passivity and transparency, IEEE Trans. Robot, vol.27, issue.4, pp.741-756, 2011. ,
Forbidden-region virtual fixtures from streaming point clouds: Remotely touching and protecting a beating heart, IEEE/RSJ Int. Conf. Intell. Rob. Syst, pp.3308-3313, 2012. ,
Occlusionfree visual servoing for the shared autonomy teleoperation of dual-arm robots, IEEE Robot. Autom. Lett, vol.3, issue.2, pp.796-803, 2018. ,
Haptic-based shared-control methods for a dual-arm system, IEEE Robot. Autom. Lett, vol.3, issue.4, pp.4249-4256, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01851712
Shared control : Balancing autonomy and human assistance with a group of quadrotor uavs, IEEE Rob. Aut. Mag, vol.19, issue.3, pp.57-68, 2012. ,
Shared autonomy via hindsight optimization for teleoperation and teaming, Int. J. Rob. Res, vol.37, issue.7, pp.717-742, 2018. ,
Shared-autonomy control for intuitive bimanual tele-manipulation, IEEE-RAS 18th Int. Conf. Human. Rob, pp.1-9, 2018. ,
Semi-autonomous teleoperation in task space with redundant slave robot under communication delays, IEEE/RSJ Int. Conf. Intell. Rob. Syst, pp.679-684, 2011. ,
Control of semi-autonomous teleoperation system with time delays, Automatica, vol.49, issue.6, pp.1553-1565, 2013. ,
A general framework for managing multiple tasks in highly redundant robotic systems, 5th Int. Conf. Adv. Rob, vol.2, pp.1211-1216, 1991. ,
User evaluation of a haptic-enabled shared-control approach for robotic telemanipulation, IEEE/RSJ Int. Conf. Intell. Rob. Syst, pp.1-9, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01851710
Shared control in haptic systems for performance enhancement and training, J. Dyn. Sys., Meas., Control, vol.128, issue.1, pp.75-85, 2006. ,
Teleoperation in cluttered environments using wearable haptic feedback, IEEE/RSJ Int. Conf. Intell. Rob. Syst, pp.3401-3408, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01572358
Active constraints using vector field inequalities for surgical robots, IEEE Int. Conf. Rob. Autom, pp.5364-5371, 2018. ,
Enhancing bilateral teleoperation using camera-based online virtual fixtures generation, IEEE/RSJ Int. Conf. Intell. Rob. Syst, pp.1483-1488, 2016. ,
Vision based virtual fixture generation for teleoperated robotic manipulation, Int. Conf. on Advanced Robotics and Mechatronics, pp.190-195, 2016. ,
Passive virtual fixtures adaptation in minimally invasive robotic surgery, IEEE Robotics and Automation Letters, vol.3, issue.4, pp.3129-3136, 2018. ,
Kinematic control of redundant robot manipulators: A tutorial, J. Intell. Robot. Syst, vol.3, issue.3, pp.201-212, 1990. ,
Stable teleoperation with time-domain passivity control, IEEE Trans. Robot. Autom, vol.20, issue.2, pp.365-373, 2004. ,
An energy tankbased interactive control architecture for autonomous and teleoperated robotic surgery, IEEE Trans. Rob, vol.31, issue.5, pp.1073-1088, 2015. ,
A tank-based approach to impedance control with variable stiffness, IEEE Int. Conf. Robot. Autom, pp.4948-4953, 2013. ,
Admittance control parameter adaptation for physical human-robot interaction, IEEE Int. Conf. Robot. Autom, pp.2911-2916, 2017. ,
Adapting to contacts: Energy tanks and task energy for passivitybased dynamic movement primitives, IEEE-RAS 17th Int. Conf. on Humanoid Robotics, pp.136-142, 2017. ,
Bilateral teleoperation of a group of uavs with communication delays and switching topology, IEEE Int. Conf. Robot. Autom, pp.4307-4314, 2012. ,
Passivation of projection-based null space compliance control via energy tanks, IEEE Robot. Autom. Lett, vol.1, issue.1, pp.184-191, 2016. ,
Passive hierarchical impedance control via energy tanks, IEEE Robot. Autom. Lett, vol.2, issue.2, pp.522-529, 2017. ,
Passive-set-position-modulation framework for interactive robotic systems, IEEE Trans. Robot, vol.26, issue.2, pp.354-369, 2010. ,
A visual-based shared control architecture for remote telemanipulation, IEEE/RSJ Int. Conf. Intell. Rob. Syst, pp.4266-4273, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01355785
Towards a self-collision aware teleoperation framework for compound robots, IEEE World Haptics Conference, pp.460-465, 2017. ,
Visp for visual servoing: a generic software platform with a wide class of robot control skills, IEEE Robot. Autom. Mag, vol.12, issue.4, pp.40-52, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00351899
