Models and Algorithms for the Product Pricing with Single-Minded Customers Requesting Bundles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Operations Research Année : 2020
We analyze a product pricing problem with single-minded customers, each interested in buying a bundle of products. The objective is to maximize the total revenue and we assume that supply is unlimited for all products. We contribute to a missing piece of literature by giving some mathematical formulations for this single-minded bundle pricing problem. We first present a mixed-integer nonlinear program with bilinear terms in the objective function and the constraints. By applying classical linearization techniques, we obtain two different mixed-integer linear programs. We then study the polyhedral structure of the linear formulations and obtain valid inequalities based on an RLT-like framework. We develop a Benders decomposition to project strong cuts from the tightest model onto the lighter models. We conclude this work with extensive numerical experiments to assess the quality of the mixed-integer linear formulations, as well as the performance of the cutting plane algorithms and the impact of the preprocessing on computation times.
preprint-20190304.pdf (562.92 Ko) Télécharger le fichier
hal-02056763 , version 1 (04-03-2019)
Víctor Bucarey, Sourour Elloumi, Martine Labbé, Fränk Plein. Models and Algorithms for the Product Pricing with Single-Minded Customers Requesting Bundles. Computers and Operations Research, 2020, ⟨10.1016/j.cor.2020.105139⟩. ⟨hal-02056763⟩
213 Consultations
841 Téléchargements
