Polyhedral Gauss maps and curvature characterisation of triangle meshes, Lecture Notes in Computer Science, vol.3604, pp.14-33, 2005. ,
, Anisotropic polygonal remeshing, vol.22, pp.485-493, 2003.
URL : https://hal.archives-ouvertes.fr/inria-00071778
, Surfaces in Range Image Understanding. Springer Series in Perception Engineering, 1988.
HÉTROY : An iterative algorithm for homology computation on simplicial shapes, Comput. Aided Design, vol.43, issue.11, pp.1457-1467, 2011. ,
ASADA : Describing surfaces, Comput. Vis. Graph. Image Process, vol.32, issue.1, pp.1-28, 1985. ,
Estimating differential quantities using polynomial fitting of osculating jets, Comput. Aided Geom. Design, vol.22, issue.2, pp.121-146, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00097582
Algorithm 889 : Jet_fitting_3 : A generic C++ package for estimating the differential properties on sampled surfaces via polynomial fitting, ACM Trans. Math. Software, vol.35, issue.3, 2008. ,
Intrinsic surface properties from surface triangulation, ECCV 1992, vol.588, pp.739-743, 1992. ,
Introduction to algorithms, 2009. ,
Discrete differential geometry : An applied introduction, SIGGRAPH 2013 courses, 2013. ,
Définition : caractéristique ,
, Differential Geometry of Curves and Surfaces, 1976.
Curvatures estimation on triangular mesh, J. Zhejiang Univ. Sci. A, vol.6, issue.1, pp.128-136, 2005. ,
Computing simplicial homology based on efficient Smith normal form algorithms, M. JOSWIG et N. TAKAYAMA, éds : Algebra, Geometry and Software Systems, pp.177-206, 2003. ,
Optimizing 3D triangulations using discrete curvature analysis, T. LYCHE et L. L. SCHUMAKER, éds : Mathematical Methods for Curves and Surfaces, pp.135-146, 2001. ,
éds : Handbook of Discrete and Computational Geometry, chap. 24, 2017. ,
Morse complexes for shape segmentation and homological analysis : discrete models and algorithms, Comput. Graph. Forum, vol.34, issue.2, pp.761-785, 2015. ,
Morse theory for cell complexes, Adv. Math, vol.134, issue.1, pp.90-145, 1998. ,
Estimating curvature on triangular meshes, Int. J. Shape Model, vol.12, issue.01, pp.1-28, 2006. ,
Two measures for the homology groups of binary volumes, DGCI 2016, vol.9647, pp.154-165, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01341015
Allowing cycles in discrete Morse theory, Topology Appl, vol.228, pp.1-35, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01528103
A topological approach to simplification of three-dimensional scalar functions, IEEE Trans. Vis. Comput. Graph, vol.12, issue.4, pp.474-484, 2006. ,
Curvature approximation for triangulated surfaces, éds : Geometric Modelling, vol.8, pp.139-153, 1993. ,
The topographic primal sketch, Int. J. Robotics Res, vol.2, issue.1, pp.50-72, 1983. ,
Modeling of Curves and Surfaces in CAD/CAM. Computer Graphics -Systems and Applications, 1992. ,
A two-level topological decomposition for non-manifold simplicial shapes, Symposium on Solid and Physical Modeling, pp.355-360, 2007. ,
A comparison of algorithms for vertex normal computation, Visual Comput, vol.21, issue.1, pp.71-82, 2005. ,
Extracting lines of curvature from noisy point clouds, Comput. Aided Design, vol.41, issue.4, pp.282-292, 2009. ,
Skeleton extraction of vertex sets lying on arbitrary triangulated 3D meshes, DGCI 2013, vol.7749, pp.203-214, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01499704
A comparison of Gaussian and mean curvature estimation methods on triangular meshes of range image data, Comput. Vis. Image Und, vol.107, issue.3, pp.139-159, 2007. ,
Weights for computing vertex normals from facet normals, J. Graph. Tools, vol.4, issue.2, pp.1-6, 1999. ,
On surface normal and Gaussian curvature approximations given data sampled from a smooth surface, Comput. Aided Geom. Design, vol.17, issue.6, pp.521-543, 2000. ,
PORT : Surface segmentation through concentrated curvature, pp.671-676, 2007. ,
Discrete curvature estimation methods for triangulated surfaces, WADGMM 2010, vol.7346, pp.28-42, 2010. ,
Discrete differential-geometry operators for triangulated 2-manifolds, HEGE et K. POLTHIER, éds : Visualization and Mathematics III, Mathematics and Visualization, pp.35-57, 2003. ,
Anisotropic remeshing based on topology of curvature-lines and isoparametric-lines of 3-dimensional surface, IWAIT 2010, 2010. ,
Segmenting molecular surfaces, Comput. Aided Geom. Design, vol.23, issue.6, pp.495-509, 2006. ,
Shape Interrogation for Computer Aided Design and Manufacturing, 2010. ,
A survey of methods for recovering quadrics in triangle meshes, ACM Comput. Surv, vol.34, issue.2, pp.211-262, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00100762
Shape-Curvature-Graph" : Towards a new model of representation for the description of 3D meshes, AVR (2), vol. 10325 de Lecture Notes in Computer Science, pp.369-384, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01794890
, Numerical Recipes -The Art of Scientific Computing, 2007.
Line-art rendering of 3D-models, PG 2000, pp.87-96, 2000. ,
, Constructive algebraic topology, vol.33, pp.13-25, 1999.
URL : https://hal.archives-ouvertes.fr/hal-00126384
A survey on mesh segmentation techniques, Comput. Graph. Forum, vol.27, issue.6, pp.1539-1556, 2008. ,
Generalized extrinsic distortion and applications, Computers & Graphics, vol.37, issue.6, pp.582-588, 2013. ,
, A Comprehensive Introduction to Differential Geometry. Publish or Perish, 1999.
Surface parametrization and curvature measurement of arbitrary 3-D objects : five practical methods, IEEE Trans. Pattern Anal. Mach. Intell, vol.14, issue.8, pp.833-840, 1992. ,
A simple method for correcting facet orientations in polygon meshes based on ray casting, Journal of Computer Graphics Techniques, vol.3, issue.4, pp.53-63, 2014. ,
Differential Geometry of Curves and Surfaces : A Concise Guide, Birkhäuser, 2005. ,
Mesh statistics for robust curvature estimation, Comput. Graph. Forum, vol.35, issue.5, pp.271-280, 2016. ,
BELYAEV : Detection of salient curvature features on polygonal surfaces, Comput. Graph. Forum, vol.20, issue.3, pp.385-392, 2001. ,
Convergence analysis of a discretization scheme for Gaussian curvature over triangular surfaces, Comput. Aided Geom. Design, vol.23, issue.2, pp.193-207, 2006. ,
SEIDEL : Fast, robust, and faithful methods for detecting crest lines on meshes, Comput. Aided Geom. Design, vol.25, issue.8, pp.545-560, 2008. ,
