GreyCat: Efficient What-If Analytics for Data in Motion at Scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information Systems Année : 2019
Over the last few years, data analytics shifted from a descriptive era, confined to the explanation of past events, to the emergence of predictive techniques. Nonetheless, existing predictive techniques still fail to effectively explore alternative futures, which continuously diverge from current situations when exploring the effects of what-if decisions. Enabling prescriptive analytics therefore calls for the design of scalable systems that can cope with the complexity and the diversity of underlying data models. In this article, we address this challenge by combining graphs and time series within a scalable storage system that can organize a massive amount of unstructured and continuously changing data into multi-dimensional data models, called Many-Worlds Graphs. We demonstrate that our open source implementation, GreyCat, can efficiently fork and update thousands of parallel worlds composed of millions of timestamped nodes, such as what-if exploration.
is.pdf (2.17 Mo) Télécharger le fichier
hal-02059882 , version 1 (26-05-2019)
Thomas Hartmann, François Fouquet, Assaad Moawad, Romain Rouvoy, Yves Le Traon. GreyCat: Efficient What-If Analytics for Data in Motion at Scale. Information Systems, inPress, 83, pp.101-117. ⟨10.1016/j.is.2019.03.004⟩. ⟨hal-02059882⟩
205 Consultations
314 Téléchargements
