A Combined CNN and LSTM Model for Arabic Sentiment Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Deep neural networks have shown good data modelling capabilities when dealing with challenging and large datasets from a wide range of application areas. Convolutional Neural Networks (CNNs) offer advantages in selecting good features and Long Short-Term Memory (LSTM) networks have proven good abilities of learning sequential data. Both approaches have been reported to provide improved results in areas such image processing, voice recognition, language translation and other Natural Language Processing (NLP) tasks. Sentiment classification for short text messages from Twitter is a challenging task, and the complexity increases for Arabic language sentiment classification tasks because Arabic is a rich language in morphology. In addition, the availability of accurate pre-processing tools for Arabic is another current limitation, along with limited research available in this area. In this paper, we investigate the benefits of integrating CNNs and LSTMs and report obtained improved accuracy for Arabic sentiment analysis on different datasets. Additionally, we seek to consider the morphological diversity of particular Arabic words by using different sentiment classification levels.
472936_1_En_12_Chapter.pdf (1.45 Mo) Télécharger le fichier
hal-02060041 , version 1 (07-03-2019)
Paternité
Abdulaziz M. Alayba, Vasile Palade, Matthew England, Rahat Iqbal. A Combined CNN and LSTM Model for Arabic Sentiment Analysis. 2nd International Cross-Domain Conference for Machine Learning and Knowledge Extraction (CD-MAKE), Aug 2018, Hamburg, Germany. pp.179-191, ⟨10.1007/978-3-319-99740-7_12⟩. ⟨hal-02060041⟩
122 Consultations
56 Téléchargements
