Compressive statistical learning with random feature moments, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01544609
Differential privacy: A survey of results, International Conference on Theory and Applications of Models of Computation, pp.1-19, 2008. ,
NP-hardness of Euclidean sum-of-squares clustering, Machine learning, vol.75, issue.2, pp.245-248, 2009. ,
Data clustering: 50 years beyond K-means, Pattern recognition letters, vol.31, issue.8, pp.651-666, 2010. ,
Least squares quantization in PCM, IEEE transactions on information theory, vol.28, issue.2, pp.129-137, 1982. ,
Random features for largescale kernel machines, Advances in neural information processing systems, pp.1177-1184, 2008. ,
Sketching for large-scale learning of mixture models, Journal of the IMA, vol.7, issue.3, pp.447-508, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01208027
Compressive K-means, International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.6369-6373, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01386077
On the'semantics' of differential privacy: A bayesian formulation, Journal of Privacy and Confidentiality, vol.6, issue.1, 2014. ,
Differential privacy under continual observation, Proceedings of the forty-second ACM symposium on Theory of computing, pp.715-724, 2010. ,
Practical differential privacy for sql queries using elastic sensitivity, 2017. ,
Calibrating noise to sensitivity in private data analysis, Theory of cryptography conference, p.20, 2006. ,
Smooth sensitivity and sampling in private data analysis, Proceedings of the thirty-ninth annual ACM symposium on Theory of computing, pp.75-84 ,
Privacy integrated queries: an extensible platform for privacy-preserving data analysis, Proceedings of the 2009 ACM SIGMOD International Conference on Management of data, pp.19-30 ,
Practical privacy: the SuLQ framework, Proceedings of the twenty-fourth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems, pp.128-138, 2005. ,
Differentially private k-means clustering, Proceedings of the Sixth ACM Conference on Data and Application Security and Privacy, pp.26-37 ,
Differential privacy: From theory to practice, Synthesis Lectures on Information Security, Privacy, & Trust, vol.8, issue.4, pp.1-138, 2016. ,
Differentially private grids for geospatial data, IEEE 29th International Conference on, pp.757-768, 2013. ,
PrivGene: differentially private model fitting using genetic algorithms, Proceedings of the 2013 international conference on Management of data -SIGMOD '13, p.665 ,
Private coresets, Proceedings of the Forty-first Annual ACM Symposium on Theory of Computing. STOC '09, pp.361-370 ,
Coresets for differentially private k-means clustering and applications to privacy in mobile sensor networks, 16th ACM/IEEE International Conference on, pp.3-16, 2017. ,
k-variates++: more pluses in the k-means++, International Conference on Machine Learning, pp.145-154 ,
Differentially private clustering in high-dimensional euclidean spaces, International Conference on Machine Learning, pp.322-331 ,
Privacy via the Johnson-Lindenstrauss Transform, Journal of Privacy and Confidentiality, vol.5, issue.1, 2013. ,
Differentially private database release via kernel mean embeddings ,
Quantized compressive k-means, IEEE Signal Processing Letters, vol.25, issue.8, pp.1211-1215 ,
Secure binary embeddings for privacy preserving nearest neighbors, Information Forensics and Security (WIFS), pp.1-6, 2011. ,
Privacy-preserving nearest neighbor methods: Comparing signals without revealing them, IEEE Signal Processing Magazine, vol.30, issue.2, pp.18-28, 2013. ,
Large-scale high-dimensional clustering with fast sketching, IEEE International Conference on Acoustics, Speech and Signal Processing ,
URL : https://hal.archives-ouvertes.fr/hal-01701121
