Enabling Fine-grained Access Control in Flexible Distributed Object-aware Process Management Systems, 21st IEEE Int'l Conf. on Enterprise Distributed Object Computing (EDOC, 2017. ,
Towards Hyperscale Process Management, 8th Int'l Workshop on Enterprise Modeling and Information Systems Architectures (EMISA), pp.148-152, 2017. ,
Extending Fragment-Based Case Management with State Variables, Business Process Management Workshops, pp.227-238, 2017. ,
Enhancing the Case Handling Paradigm to Support Object-aware Processes, 3rd Int'l Symposium on Data-Driven Process Discovery and Analysis (SIMPDA), pp.89-103, 2013. ,
Business Artifacts: A Data-centric Approach to Modeling Business Operations and Processes, Bulletin of the IEEE Computer Society Technical Committee on Data Engineering, vol.32, issue.3, pp.3-9, 2009. ,
On the Equivalence of Incremental and Fixpoint Semantics for Business Artifacts with Guard-Stage-Milestone Lifecycles, formation Systems, vol.38, pp.561-584, 2013. ,
Supporting Flexible Processes with Adaptive Workflow and Case Handling, IEEE 17th Workshop on Enabling Technologies: Infrastructure for Collaborative Enterprises, pp.229-234, 2008. ,
A Framework for Data-Driven Workflow Management: Modeling, Verification and Execution, 24th Int'l Conf. on Database and Expert Systems Applications (DEXA), vol.8055, pp.239-253, 2013. ,
Opus framework: A Proof-of-Concept Implementation, IEEE/ACIS 14th Int'l Conf. on Computer and Information Science (ICIS), pp.639-641, 2015. ,
A Data-centric Approach to Manage Business Processes, Computing, vol.98, issue.4, pp.375-406, 2016. ,
DOI : 10.1007/s00607-015-0440-2
, Understanding Declare Models: Strategies, Pitfalls, Empirical Results. Software & Systems Modeling, vol.15, pp.325-352, 2016.
DOI : 10.1007/s10270-014-0435-z
URL : https://link.springer.com/content/pdf/10.1007%2Fs10270-014-0435-z.pdf
A Hybrid Approach for Flexible Case Modeling and Execution, Business Process Management Forum, pp.38-54, 2016. ,
DOI : 10.1007/978-3-319-45468-9_3
Business Artifacts with Guard-Stage-Milestone Lifecycles: Managing Artifact Interactions with Conditions and Events, 5th ACM Int'l Conf. on Distributed Event-based System (DEBS), pp.51-62, 2011. ,
DOI : 10.1145/2002259.2002270
, Introducing the Guard-Stage-Milestone Approach for Specifying Business Entity Lifecycles. In: 7th Int'l Workshop on Web Services and Formal Methods (WS-FM) 2010. Lecture Notes in Computer Science, vol.6551, pp.1-24, 2011.
DOI : 10.1007/978-3-642-19589-1_1
A Modeling Paradigm for Integrating Processes and Data at the Micro Level, 12th Int'l Working Conf. on Business Process Modeling, Development and Support (BPMDS), pp.201-215, 2011. ,
PHILharmonicFlows: Towards a Framework for Objectaware Process Management, Journal of Software Maintenance and Evolution: Research and Practice, vol.23, issue.4, pp.205-244, 2011. ,
Business Artifacts: An Approach to Operational Specification, IBM Systems Journal, vol.42, issue.3, pp.428-445, 2003. ,
DOI : 10.1147/sj.423.0428
, Object Management Group: Case Management Model and Notation (CMMN), Version, vol.1, 2016.
DECLARE: Full Support for Loosely-Structured Processes, 11th IEEE Int'l Conf. on Enterprise Distributed Object Computing (EDOC), p.287, 2007. ,
DOI : 10.1109/edoc.2007.14
URL : http://wwwis.win.tue.nl/~wvdaalst/publications/p419.pdf
, Imperative versus Declarative Process Modeling Languages: An Empirical Investigation, pp.383-394, 2012.
DOI : 10.1007/978-3-642-28108-2_37
The Case Handling Case, International Journal of Cooperative Information Systems, vol.12, issue.03, pp.365-391, 2003. ,
DOI : 10.1142/s0218843003000784
, The Relational Process Structure. In: 30th Int'l Conf. on Advanced Information Systems Engineering (CAiSE), pp.53-67, 2018.
DOI : 10.1007/978-3-319-91563-0_4
Coordinating Business Processes Using Semantic Relationships, 19th IEEE Conf. on Business Informatics (CBI), pp.33-43, 2017. ,
DOI : 10.1109/cbi.2017.53
Case Handling: A New Paradigm for Business Process Support, Data & Knowledge Engineering, vol.53, issue.2, pp.129-162, 2005. ,
Investigating the Effort of Using Business Process Management Technology: Results from a Controlled Experiment, Science of Computer Programming, vol.75, issue.5, pp.292-310, 2010. ,
