The Deviation Attack: A Novel Denial-of-Service Attack Against IKEv2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In previous analyses IKEv2 has been shown to suffer from an authentication vulnerability that was considered not exploitable. By designing and implementing a novel slow Denial-of-Service attack, which we name the Deviation Attack, we show that the vulnerability is actually exploitable. We explain the attack’s requirements, propose possible counter-measures and propose two possible modifications of the protocol, which both overcome the vulnerability.
trustcomsubmitted.pdf (403.52 Ko) Télécharger le fichier
hal-01980276 , version 1 (25-01-2019)
hal-01980276 , version 2 (22-10-2019)
  • HAL Id : hal-01980276 , version 2
Tristan Ninet, Axel Legay, Romaric Maillard, Louis-Marie Traonouez, Olivier Zendra. The Deviation Attack: A Novel Denial-of-Service Attack Against IKEv2. TrustCom 2019 - 18th IEEE International Conference on Trust, Security and Privacy in Computing and Communications, Aug 2019, Rotorua, New Zealand. pp.1-8. ⟨hal-01980276v2⟩
462 Consultations
1198 Téléchargements
