New interface
Conference papers
Estimation of Axonal Conduction Speed and the Inter Hemispheric Transfer Time using Connectivity Informed Maximum Entropy on the Mean
Abstract : The different lengths and conduction velocities of axons connecting cortical regions of the brain yield information transmission delays which are believed to be fundamental to brain dynamics. A critical step in the estimation of axon conduction speed in vivo is the estimation of the inter hemispheric transfer time (IHTT). The IHTT is estimated using electroencephalography (EEG) by measuring the latency between the peaks of specific electrodes or by computing the lag to maximum correlation on contra lateral electrodes. These approaches do not take the subject's anatomy into account and, due to the limited number of electrodes used, only partially leverage the information provided by EEG. Using the previous published Connectivity Informed Maximum Entropy on the Mean (CIMEM) method, we propose a new approach to estimate the IHTT. In CIMEM, a Bayesian network is built using the structural connectivity information between cortical regions. EEG signals are then used as evidence into this network to compute the posterior probability of a connection being active at a particular time. Here, we propose a new quantity which measures how much of the EEG signals are supported by connections, which is maximized when the correct conduction delays are used. Using simulations, we show that CIMEM provides a more accurate estimation of the IHTT compared to the peak latency and lag to maximum correlation methods.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-02063396
Contributor : Samuel Deslauriers-Gauthier Connect in order to contact the contributor
Submitted on : Monday, March 11, 2019 - 10:52:14 AM
Last modification on : Saturday, July 23, 2022 - 3:53:02 AM
Long-term archiving on: : Wednesday, June 12, 2019 - 1:26:06 PM
File
main.pdf
Identifiers
  • HAL Id : hal-02063396, version 1
Citation
Samuel Deslauriers-Gauthier, Rachid Deriche. Estimation of Axonal Conduction Speed and the Inter Hemispheric Transfer Time using Connectivity Informed Maximum Entropy on the Mean. SPIE Medical Imaging 2019, Feb 2019, San Diego, United States. ⟨hal-02063396⟩
Share
Metrics
Record views
129
Files downloads
226
