Performance Evaluation of Metro Regulations Using Probabilistic Model-checking
Metros are subject to unexpected delays due to weather conditions , incidents, passenger misconduct, etc. To recover from delays and avoid their propagation to the whole network, metro operators use regulation algorithms that adapt speeds and departure dates of trains. Regulation algorithms are ad-hoc tools that are tuned to cope with characteristics of tracks, rolling stock, and passengers habits. However, there is no universal optimal regulation adapted in any environment. So, performance of a regulation technique must be evaluated before its integration in the network. In this work, we use probabilistic model-checking to evaluate the performance of regulation algorithms in simple metro lines. We model the moves of trains and random delays with Markov decision processes, and regulation as a controller that forces a decision depending on its partial knowledge of the state of the system. We then use the probabilistic model checker PRISM to evaluate performance of regulation: We compute the probability to reach a stable situation from an unstable one in less than d time units, letting d vary in a large enough time interval. This approach is applied on a case study, the metro network of Glasgow.
Théorie et langage formel [cs.FL]
