Implicit parallelism through deep language embedding, SIGMOD Record, vol.45, issue.1, pp.51-58, 2016. ,
Representations and optimizations for embedded parallel dataflow languages, ACM Trans. Database Syst, vol.44, issue.1, 2019. ,
Comprehension syntax, SIGMOD Rec, vol.23, issue.1, pp.87-96, 1994. ,
Apache flink TM : Stream and batch processing in a single engine, IEEE Data Eng. Bull, vol.38, issue.4, pp.28-38, 2015. ,
On the Optimization of Iterative Programmingwith Distributed Data Collections, 2020. ,
Mapreduce: Simplified data processing on large clusters, 6th Symposium on Operating System Design and Implementation (OSDI 2004), pp.137-150, 2004. ,
An algebra for distributed big data analytics, Journal of Functional Programming, vol.27, p.27, 2017. ,
Optimizing object queries using an effective calculus, ACM Trans. Database Syst, vol.25, issue.4, pp.457-516, 2000. ,
Compile-time code generation for embedded dataintensive query languages, 2018 IEEE International Congress on Big Data, pp.1-8, 2018. ,
In: A List of Successes That Can Change the World -Essays Dedicated to Philip Wadler on the Occasion of His 60th Birthday, Lecture Notes in Computer Science, vol.9600, pp.132-151, 2016. ,
Ferry: Database-supported program execution, Proceedings of the 2009 ACM SIGMOD International Conference on Management of Data, pp.1063-1066, 2009. ,
YAGO: A high-quality knowledge base, 2019. ,
On the optimization of recursive relational queries: Application to graph queries, Proceedings of the ACM SIGMOD International Conference on Management of Data, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-01673025
, Snap: Stanford large network dataset collection, 2019.
Emma is a quotation-based scala dsl for scalable data analysis, 2019. ,
LINQ: reconciling object, relations and XML in the .net framework, Proceedings of the ACM SIGMOD International Conference on Management of Data, p.706, 2006. ,
An overview of the scala programming language, Tech. rep, 2004. ,
The Implementation of Functional Programming Languages (Prentice-Hall International Series in Computer Science), 1987. ,
Big data analytics with datalog queries on spark, Proceedings of the 2016 International Conference on Management of Data, SIGMOD Conference, pp.1135-1149, 2016. ,
Structural recursion as a query language, Database Programming Languages: Bulk Types and Persistent Data. 3rd International Workshop, pp.9-19, 1991. ,
Data structures and data types for objectoriented databases, IEEE Data Eng. Bull, vol.14, issue.2, pp.23-27, 1991. ,
Recursion Equations as a Programming Language, pp.459-478, 2016. ,
Comprehending monads, Mathematical Structures in Computer Science, vol.2, issue.4, pp.461-493, 1992. ,
Apache spark: a unified engine for big data processing, Commun. ACM, vol.59, issue.11, pp.56-65, 2016. ,
Fixpoint semantics and optimization of recursive datalog programs with aggregates. Theory Pract, Log. Program, vol.17, issue.5-6, pp.1048-1065, 2017. ,
, A: R f ? R ? µ(R f , ?) ? µ(R, ?) (because µ(R, ?) = µ(R f R , ?) = µ(R f , ?) ? µ(R , ?)
Let s ? A, s ? µ(R, ?) and c(? a (s)) = true So ?r ? R ?n ? N ? a (s) = ? a (r) (*) and s ? ? (n) ({r}) So c(? a (r)) = c(? a (s)) = true So r ? R f , which means distinct(? (n) ({r})) ? µ(R f , ?) (see fixpoint related proofs in Appendix C.1) ,
count) = (R,empty,d,c) STEP (setDiff((SELECT DISTINCT (x, t) FROM (x,y) <-X, (z,t) <-R WHERE y == z), O), setUnion(O,X) ,
SELECT DISTINCT (x, t,l+m) FROM (x,y,l) <-X, (z,t,m) <-R WHERE y == z).coalesce(p).cache(), setUnion(O,X), count, O.count()) UNTIL count == oldCount, UNTIL count == oldCount Shortest paths: REPEAT ,
City(n1,l1), cd) <-routes WHERE y == n1).coalesce(p).cache(), setUnion(O,X) ,
, count) = (startMovieNames,empty,d,c) STEP (setDiff((SELECT DISTINCT m FROM (lm,e) <-( SELECT (lu, x) from User(u,lu) <-userslocal, x <-X WHERE lu.map(_.name).contains(x)), Movie(m) <-lm ),O)
