Solutions to inverse moment estimation problems in dimension 2, using best constrained approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Approximation Theory Année : 2020
Elodie Pozzi
  • Fonction : Auteur
  • PersonId : 1044023
We study an inverse problem that consists in estimating the first (zero-order) moment of some R2-valued distribution m supported within a closed interval S ⊂ R, from partial knowledge of the solution to the Poisson-Laplace partial differential equation with source term equal to the divergence of m on another interval parallel to and located at some distance from S. Such a question coincides with a 2D version of an inverse magnetic "net" moment recovery question that arises in paleomagnetism, for thin rock samples. We formulate and constructively solve a best approximation problem under constraint in L2 and in Sobolev spaces involving the restriction of the Poisson extension of the divergence of m. Numerical results obtained from the described algorithms for the net moment approximation are also furnished.
BEPvarxiv.pdf (663.76 Ko) Télécharger le fichier
hal-02066780 , version 1 (26-03-2019)
Juliette Leblond, Elodie Pozzi. Solutions to inverse moment estimation problems in dimension 2, using best constrained approximation. Journal of Approximation Theory, inPress, ⟨10.1016/j.jat.2020.105520⟩. ⟨hal-02066780⟩
65 Consultations
106 Téléchargements
