Isogeometric analysis using T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.229-263, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01517950
Homology of smooth splines: generic triangulations and a conjecture of strang, Transactions of the american Mathematical Society, vol.310, issue.1, pp.325-340, 1988. ,
A dimension series for multivariate splines, vol.6, pp.107-128 ,
On the dimension of Tchebycheffian spline spaces over planar T-meshes, Computer Aided Geometric Design, vol.45, pp.151-173, 2016. ,
Tchebycheffian spline spaces over planar T-meshes: Dimension bounds and dimension instabilities, Journal of Computational and Applied Mathematics, vol.349, pp.265-278, 2019. ,
Some properties of LR-splines, Computer Aided Geometric Design, vol.30, issue.8, pp.778-794, 2013. ,
Characterization of analysis-suitable T-splines, Computer Aided Geometric Design, vol.39, pp.17-49, 2015. ,
Linear independence of the T-spline blending functions associated with some particular T-meshes, Computer Methods in Applied Mechanics and Engineering, vol.199, pp.1437-1445, 2010. ,
Isogeometric Analysis: Toward Integration of CAD and FEA, 2009. ,
Polynomial splines over hierarchical T-meshes, Graphical Models, vol.70, issue.4, pp.76-86, 2008. ,
Polynomial splines over locally refined box-partitions. Computer Aided Geometric Design, vol.30, pp.331-356, 2013. ,
Polynomial splines over locally refined boxpartitions, Computer Aided Geometric Design, vol.30, issue.3, pp.331-356, 2013. ,
Hierarchical B-spline refinement, ACM SIGGRAPH Computer Graphics, vol.22, pp.205-212, 1988. ,
THB-splines: The truncated basis for hierarchical splines, Computer Aided Geometric Design, vol.29, issue.7, pp.485-498, 2012. ,
, Macaulay2, a software system for research in algebraic geometry. Available at
Isogeometric analysis using LR B-splines, Computer Methods in Applied Mechanics and Engineering, vol.269, pp.471-514, 2014. ,
Adaptive and linearly independent multilevel b-splines, Surface Fitting and Multiresolution Methods, pp.209-218, 1997. ,
On the instability in the dimension of splines spaces over t-meshes, vol.28, pp.420-426 ,
On linear independence of t-spline blending functions, vol.29, pp.63-76 ,
On the dimension of spline spaces on planar t-meshes, Mathematics of Computation, vol.83, issue.286, pp.847-871, 2014. ,
URL : https://hal.archives-ouvertes.fr/inria-00533187
Computational algebraic geometry, vol.58, 2003. ,
Approximation power of polynomial splines on T-meshes, Computer Aided Geometric Design, vol.29, issue.8, pp.599-612, 2012. ,
Local refinement of analysis-suitable T-splines, Computer Methods in Applied Mechanics and Engineering, pp.206-222, 2012. ,
, ACM SIGGRAPH 2003 Papers, SIGGRAPH '03, pp.477-484, 2003.
T-splines and t-nurccs, ACM transactions on graphics (TOG), vol.22, pp.477-484, 2003. ,
Computation of multi-degree B-splines, 2018. ,
U-splines: Splines over unstructured meshes, 2018. ,
Supplementary Macaulay2 scripts for splines on T-meshes ,
Multi-degree B-splines: Algorithmic computation and properties, 2018. ,
Multi-degree smooth polar splines: A framework for geometric modeling and isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.316, pp.1005-1061, 2017. ,
