New interface
Preprints, Working Papers, ...
COCO: The Large Scale Black-Box Optimization Benchmarking (bbob-largescale) Test Suite
Abstract : The bbob-largescale test suite, containing 24 single-objective functions in continuous domain, extends the well-known single-objective noiseless bbob test suite, which has been used since 2009 in the BBOB workshop series, to large dimension. The core idea is to make the rotational transformations R, Q in search space that appear in the bbob test suite computationally cheaper while retaining some desired properties. This documentation presents an approach that replaces a full rotational transformation with a combination of a block-diagonal matrix and two permutation matrices in order to construct test functions whose computational and memory costs scale linearly in the dimension of the problem.
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-02068407
Contributor : Dimo Brockhoff Connect in order to contact the contributor
Submitted on : Tuesday, March 26, 2019 - 3:12:37 PM
Last modification on : Friday, February 4, 2022 - 3:08:38 AM
Long-term archiving on: : Thursday, June 27, 2019 - 5:00:23 PM
bbob-largescale-functions.pdf
Identifiers
  • HAL Id : hal-02068407, version 2
  • ARXIV : 1903.06396
Citation
Ouassim Ait Elhara, Konstantinos Varelas, Duc Hung Nguyen, Tea Tušar, Dimo Brockhoff, et al.. COCO: The Large Scale Black-Box Optimization Benchmarking (bbob-largescale) Test Suite. 2019. ⟨hal-02068407v2⟩
Share
Metrics
Record views
269
Files downloads
329
