Training on the Edge: The why and the how - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (2) , (2) , (1) , (3) , (3) , (1)
1
2
3
Edge computing is the natural progression from Cloud computing, where, instead of collecting all data and processing it centrally, like in a cloud computing environment, we distribute the computing power and try to do as much processing as possible, close to the source of the data. There are various reasons this model is being adopted quickly, including privacy, and reduced power and bandwidth requirements on the Edge nodes. While it is common to see inference being done on Edge nodes today, it is much less common to do training on the Edge. The reasons for this range from computational limitations, to it not being advantageous in reducing communications between the Edge nodes. In this paper, we explore some scenarios where it is advantageous to do training on the Edge, as well as the use of checkpointing strategies to save memory.
1903.03051.pdf (331.8 Ko) Télécharger le fichier
Dates and versions
hal-02069728 , version 1 (15-03-2019)
Identifiers
  • HAL Id : hal-02069728 , version 1
Cite
Navjot Kukreja, Alena Shilova, Olivier Beaumont, Jan Hückelheim, Nicola Ferrier, et al.. Training on the Edge: The why and the how. PAISE2019 - 1st Workshop on Parallel AI and Systems for the Edge, May 2019, Rio de Janeiro, Brazil. ⟨hal-02069728⟩
Collections
CNRS INRIA INRIA2
96 View
59 Download
Share
