Foundations of Databases, 1995. ,
, Saravanan Thirumuruganathan, and Anis Troudi. 2018. RHEEM: Enabling Cross-Platform Data Processing -May The Big Data Be With You! PVLDB, 2018.
Fast Algorithms for Mining Association Rules in Large Databases, PVLDB, 1994. ,
H2O: a hands-free adaptive store, SIGMOD, 2014. ,
Spark SQL: Relational data processing in Spark, SIGMOD, 2015. ,
Mixed-instance querying: a lightweight integration architecture for data journalism, VLDB, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01321201
ViewJoin: Efficient view-based evaluation of tree pattern queries, ICDE, 2010. ,
, CoPhy: A Scalable, Portable, and Interactive Index Advisor for Large Workloads. PVLDB, 2011.
Rewriting Queries Using Views with Access Patterns Under Integrity Constraints, ICDT, 2005. ,
The chase revisited, PODS, 2008. ,
Query reformulation with constraints, 2006. ,
MARS: A System for Publishing XML from Mixed and Redundant Storage, 2003. ,
Reformulation of XML Queries and Constraints, ICDT, 2003. ,
, The BigDAWG Polystore System. SIGMOD, 2015.
Data Exchange: Semantics and Query Answering, ICDT, 2003. ,
Data exchange: semantics and query answering, Theoretical Computer Science, 2005. ,
SilkRoute: A framework for publishing relational data in XML, TODS, 2002. ,
Query Optimization in the Presence of Limited Access Patterns, SIGMOD, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00073035
Calibrating the Query Optimizer Cost Model of IRO-DB, an Object-Oriented Federated Database System, VLDB, pp.378-389, 1996. ,
Tableau Techniques for Querying Information Sources through Global Schemas, ICDT, 1999. ,
, Anatomy of the chase, 2013.
Optimizing queries across diverse data sources, 1997. ,
Clio grows up: from research prototype to industrial tool, SIGMOD, 2005. ,
Answering Queries Using Views: A Survey, The VLDB Journal, 2001. ,
, Database Cracking. In CIDR, 2007.
Complete yet practical search for minimal query reformulations under constraints, SIGMOD, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01086494
, SQL:1999, pp.9075-9076, 1999.
WWHow! Freeing Data Storage from Cages, CIDR, 2013. ,
MIMIC-III, a freely accessible critical care database, Scientific Data, 2016. ,
Just-In-Time Data Virtualization: Lightweight Data Management with ViDa, CIDR, 2015. ,
Materialized view selection for XQuery workloads, SIGMOD, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00680365
CloudMdsQL: querying heterogeneous cloud data stores with a common language, 2016. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01184016
MISO: souping up big data query processing with a multistore system, SIGMOD, 2014. ,
Opportunistic physical design for big data analytics, SIGMOD, 2014. ,
Querying Heterogeneous Information Sources Using Source Descriptions, VLDB, 1996. ,
How to Fit when No One Size Fits, CIDR, 2013. ,
Answering XML Queries on Heterogeneous Data Sources, VLDB, 2001. ,
Processing First-Order Queries under Limited Access Patterns, PODS, 2004. ,
Rewriting Nested XML Queries Using Nested Views, SIGMOD, 2006. ,
Principles of Distributed Database Systems, 2011. ,
Semistructured Models, Queries and Algebras in the Big Data Era: Tutorial Summary, SIGMOD, 2016. ,
InterJoin: Exploiting Indexes and Materialized Views in XPath Evaluation, SSDBM, 2006. ,
A chase too far, ACM SIGMOD Record, vol.29, pp.273-284, 2000. ,
Answering Queries Using Templates with Binding Patterns, PODS, 1995. ,
Access Path Selection in a Relational Database Management System, SIGMOD, 1979. ,
F1: A Distributed SQL Database That Scales, PVLDB, 2013. ,
One Size Fits All": An Idea Whose Time Has Come and Gone, ICDE, 2005. ,
a d m i s s i o n s " , " o " ) , Chil d J ( A , a d m i s s i o n I D , " a d m i s s i o n I D, V al ue J ( r e p o r t ,
) , Chil d J ( A , a d m i s s i o n I D , " a d m i s s i o n I D, Chil d J ( A , a d m i s s i o n T i m e ,
Chil d J V 1 ( d 1 , a d m i s s i o n I D , " a d m i s s i o n I D, Chil d J V 1 ,
a d m i s s i o n s " , " o " ) , Chil d J ( A , a d m i s s i o n I D , " a d m i s s i o n I D, Chil d J (M, A ,
, d m i s s i o n I D , a d m i s s i o n L o c , a d m i s s i o n T, vol.2
a d m i s s i o n L o c, { " i t e m " : " $ADMISSIONS . LABEVENTS . ITEMID " } , " p i p e l i n e " : [ { " $match " : { " $ e x p r " : { " $and ,
, Chil d J
, Chil d J
CATEGORY, Chil d J ( L , CATEGORY ,
