, We illustrate here a bound on the efficiency factor ? in (5.1) for different choices
A preconditioner based on domain decomposition for h-p finite-element approximation on quasi-uniform meshes, SIAM J. Numer. Anal, vol.33, pp.1358-1376, 1996. ,
V -cycle multigrid algorithms for discontinuous Galerkin methods on non-nested polytopic meshes, J. Sci. Comput, vol.78, pp.625-652, 2019. ,
A uniform additive Schwarz preconditioner for high-order discontinuous Galerkin approximations of elliptic problems, J. Sci. Comput, vol.70, pp.608-630, 2017. ,
Stopping criteria for adaptive finite element solvers, SIAM, J. Sci. Comput, vol.35, pp.1537-1559, 2013. ,
Efficient preconditioning for the p-version finite element method in two dimensions, SIAM J. Numer. Anal, vol.28, pp.624-661, 1991. ,
The hierarchical basis multigrid method, Numer. Math, vol.52, pp.427-458, 1988. ,
Algebraic multigrid for discontinuous Galerkin discretizations of heterogeneous elliptic problems, Numer. Linear Algebra Appl, vol.19, pp.367-388, 2012. ,
Adaptive error control for multigrid finite element methods, Computing, vol.55, pp.271-288, 1995. ,
The cascadic multigrid method for elliptic problems, Numer. Math, vol.75, pp.135-152, 1996. ,
h-multigrid agglomeration based solution strategies for discontinuous Galerkin discretizations of incompressible flow problems, J. Comput. Phys, vol.347, pp.382-415, 2017. ,
The construction of preconditioners for elliptic problems by substructuring. I, Math. Comp, vol.47, pp.103-134, 1986. ,
Parallel multilevel preconditioners, in Numerical analysis, Pitman Res. Notes Math. Ser., Longman Sci. Tech, vol.228, pp.23-39, 1989. ,
Algebraic multigrid (AMG) for sparse matrix equations, Sparsity and its applications (Loughborough, 1983), pp.257-284, 1985. ,
, The mathematical theory of finite element methods, vol.15, 2008.
A restricted additive Schwarz preconditioner for general sparse linear systems, SIAM J. Sci. Comput, vol.21, pp.792-797, 1999. ,
Preconditioned minimal residual methods for Chebyshev spectral calculations, J. Comput. Phys, vol.60, pp.315-337, 1985. ,
Optimal multilevel methods for graded bisection grids, Numer. Math, vol.120, pp.1-34, 2012. ,
The finite element method for elliptic problems, Studies in Mathematics and its Applications, vol.4, 1978. ,
, Why restricted additive Schwarz converges faster than additive Schwarz, pp.945-959, 2003.
, Theory and practice of finite elements, vol.159, 2004.
Multilevel solution method for the p-version of finite elements, Computer Physics Communications, vol.53, pp.349-355, 1989. ,
A comparative study of state-of-the-art Poisson solvers for uniform and nonuniform grids in the unit cube, SIAM J. Sci. Comput, vol.38, pp.280-306, 2016. ,
A particle-partition of unity method. VI. A probust multilevel solver, Meshfree methods for partial differential equations II, vol.43, pp.71-92, 2005. ,
, of Springer Series in Computational Mathematics, vol.4, 2003.
Line relaxation for spectral multigrid methods, J. Comput. Phys, vol.77, pp.166-182, 1988. ,
Uniform convergence of adaptive multigrid methods for elliptic problems and Maxwell's equations, Numer. Math. Theory Methods Appl, vol.5, pp.297-332, 2012. ,
Adaptive multilevel methods with local smoothing for H 1 -and H curlconforming high order finite element methods, SIAM, J. Sci. Comput, vol.33, pp.2095-2114, 2011. ,
A posteriori error estimates including algebraic error and stopping criteria for iterative solvers, SIAM J. Sci. Comput, vol.32, pp.1567-1590, 2010. ,
Robust smoothers for high-order discontinuous Galerkin discretizations of advectiondiffusion problems, J. Comput. Appl. Math, vol.218, pp.53-60, 2008. ,
A performance comparison of continuous and discontinuous Galerkin methods with fast multigrid solvers, SIAM J. Sci. Comput, vol.40, pp.3423-3448, 2018. ,
On hybrid multigrid-Schwarz algorithms, J. Sci. Comput, vol.36, pp.165-175, 2008. ,
Multilevel Schwarz preconditioners for singularly perturbed symmetric reaction-diffusion systems, 2018. ,
Two-level domain decomposition preconditioning for the p-version finite element method in three dimensions, Internat. J. Numer. Methods Engrg, vol.29, pp.1095-1108, 1990. ,
Goal-oriented error control of the iterative solution of finite element equations, J. Numer. Math, vol.17, pp.143-172, 2009. ,
Numerical optimization, Springer Series in Operations Research and Financial Engineering, 2006. ,
A massively parallel solver for discrete Poisson-like problems, J. Comput. Phys, vol.281, pp.237-250, 2015. ,
Multilevel finite element approximation, Teubner Skripten zur Numerik, Theory and applications, 1994. ,
Sharp algebraic and total a posteriori error bounds for h and p finite elements via a multilevel approach. Recovering mass balance in any situation, 2019. ,
Estimating and localizing the algebraic and total numerical errors using flux reconstructions, Numer. Math, vol.138, pp.681-721, 2018. ,
Inexpensive guaranteed and efficient upper bounds on the algebraic error in finite element discretizations. HAL preprint 02422851, 2019. ,
Additive Schwarz methods for the p-version finite element method, Numer. Math, vol.66, pp.493-515, 1994. ,
Domain decomposition preconditioners for the spectral collocation method, J. Sci. Comput, vol.3, pp.45-76, 1988. ,
Additive Schwarz preconditioning for p-version triangular and tetrahedral finite elements, IMA J. Numer. Anal, vol.28, pp.1-24, 2008. ,
C++11 Implementation of Finite Elements in NGsolve, tech. rep., ASC Report 30/2014, Institute for Analysis and Scientific Computing, 2014. ,
Automatic generation of triangulations for piecewise polynomial approximation, Pro-Quest LLC, 1972. ,
Comparison of multigrid algorithms for high-order continuous finite element discretizations, Numer, Linear Algebra Appl, vol.22, pp.664-680, 2015. ,
An explicit construction of interpolation nodes on the simplex, J. Engrg. Math, vol.56, pp.247-262, 2006. ,
Uniform convergence of multigrid V-cycle on adaptively refined finite element meshes for second order elliptic problems, Sci. China Ser. A, vol.49, pp.1405-1429, 2006. ,
Iterative methods by space decomposition and subspace correction, SIAM Rev, vol.34, pp.581-613, 1992. ,
Optimal multilevel methods for H(grad), H(curl), and H(div) systems on graded and unstructured grids, in Multiscale, nonlinear and adaptive approximation, pp.599-659, 2009. ,
Multilevel Schwarz methods, Numer. Math, vol.63, pp.521-539, 1992. ,
