Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : With increasing maturity in model-based design and construction, a concomitant increase in the need for system-based methodologies and toolsets to support systems integration, requirements management, verification and validation and configuration management is evident if model-based information is to serve the operations of complex buildings and civil infrastructure projects. There is much to learn from best practices reported in complex discrete manufacturing. In particular, closed-loop product lifecycle management (PLM), systems engineering (SE) and model-based systems engineering (MBSE) are key to systems approaches to digital complex construction delivery and the reuse of model-based information for operations and maintenance (O&M). The paper reviews related research and investigates the role of the V-model in the development process, discussing its significance to structuring a through-life approach to information management. A discussion of Erasmus’ PLM aligned V-model is presented, and missing links in current BIM-enabled environments are identified relative to requirements engineering, verification and validation, and configuration management. The paper closes with a discussion of the gaps in supporting model-based tool ecologies and lack of a central structuring infrastructure, as well as the deficiencies in current process and data standards. Closing with the identification of a future research agenda.
https://hal.inria.fr/hal-02075560 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, March 21, 2019 - 2:46:25 PM Last modification on : Wednesday, November 3, 2021 - 8:12:32 AM Long-term archiving on: : Saturday, June 22, 2019 - 2:31:28 PM
yu Chen, Julie Jupp. Model-Based Systems Engineering and Through-Life Information Management in Complex Construction. 15th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2018, Turin, Italy. pp.80-92, ⟨10.1007/978-3-030-01614-2_8⟩. ⟨hal-02075560⟩
