Pathways and patterns of metaphor and metonymy in Mixtepec-Mixtec body-part terms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In accordance with data published from several related varieties of Mixtecan, and numerous other languages, Mixtepec-Mixtec body-part terms feature expansive networks of extended senses as the head component of a compound, in multi-word expressions and polysemous forms. Parts of the body which have given rise to other meanings in Mixtepec-Mixtec and/or in other forms of Mixtec are: ‘head,’ ‘face’, ‘back’ ’foot’, ‘leg’, ‘back’, ’hand/arm’, ‘belly/stomach’, ‘mouth’. Of these, as is the case in related Mixtecan varieties, ‘face’ and ‘foot’ are the most productive, as we will see, have undergone multiple stages of extensions.
JBowers-MixtepecMixtec-FINAL.pdf (405.47 Ko) Télécharger le fichier
hal-02075731 , version 1 (21-03-2019)
hal-02075731 , version 2 (08-08-2019)
hal-02075731 , version 3 (05-02-2020)
hal-02075731 , version 4 (20-04-2020)
hal-02075731 , version 5 (18-05-2020)
hal-02075731 , version 6 (30-05-2020)
hal-02075731 , version 7 (07-06-2020)
hal-02075731 , version 8 (14-09-2022)
  • HAL Id : hal-02075731 , version 5
Jack Bowers. Pathways and patterns of metaphor and metonymy in Mixtepec-Mixtec body-part terms. 2020. ⟨hal-02075731v5⟩
430 Consultations
454 Téléchargements
