Photometric Intensity Profiles Analysis for Thick Segment Recognition and Geometric Measures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Morphology - Theory and Applications Année : 2017
The segmentation or the geometric analysis of specular objects is known as a difficult problem in the computer vision domain. It is also true for the problem of line detection where the specular reflection implies numerous false positive line detection or missing lines located on the dark parts of the object. This limitation reduces its potential use for concrete industrial applications where metallic objects are frequent. In order to overcome this limitation, a new strategy to detect thick segment is proposed. It is not based on the image gradient as usually, but rather exploits the image intensity profile defined inside a parallel strip primitive. Associated to a digital straight segment recognition algorithmwhich is robust to noise, this strategy was implemented to track metallic tubular objects in gray-level images. The efficiency of the proposed method is demonstrated through extensive tests using an actual industrial application. An alternate release intended to overcome the possible impact of the digitization process on the achieved performance is also introduced. Both strategies are discussed at the end of the article.
hal-02077892 , version 1 (24-03-2019)
Nicolas Aubry, Bertrand Kerautret, Philippe Even, Isabelle Debled-Rennesson. Photometric Intensity Profiles Analysis for Thick Segment Recognition and Geometric Measures. Mathematical Morphology - Theory and Applications, 2017, 2 (1), pp.34-54. ⟨10.1515/mathm-2017-0003⟩. ⟨hal-02077892⟩
63 Consultations
0 Téléchargements
