Soft robotics: A perspective, current trends and prospects for the future, Soft Robotics, 2014. ,
, Soft robotics: a bioinspired evolution in robotics, Trends in Biotechnology, vol.31, issue.5
Design, fabrication and control of soft robots, Nature, 2015. ,
Design and kinematic modeling of constant curvature continuum robots: A review, The International Journal of Robotics Research, vol.29, issue.13 ,
Visual servoing of soft robot manipulator in constrained environments with an adaptive controller, Transactions on Mechatronics, vol.22, 2017. ,
A feed-forward neural network learning the inverse kinetics of a soft cable-driven manipulator moving in three-dimensional space, International Conference on Intelligent Robots and Systems, 2013. ,
Model-less feedback control of continuum manipulators in constrained environments, Transactions on Robotics, vol.30, issue.4, 2014. ,
Using Physical Modeling and RGB-D Registration for Contact Force Sensing on Deformable Objects, International Conference on Informatics in Control, Automation and Robotics, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01617243
Vision-based sensing of external forces acting on soft robots using finite element method, Robotics and Automation Letters, vol.3, issue.3, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01720645
Software toolkit for modeling, simulation, and control of soft robots, Advanced Robotics, vol.31 ,
URL : https://hal.archives-ouvertes.fr/hal-01649355
Optimization-based inverse model of soft robots with contact handling, Robotics and Automation Letters (Proc. ICRA), vol.2, 2017. ,
DOI : 10.1109/lra.2017.2669367
URL : https://hal.archives-ouvertes.fr/hal-01500912
Direct control of simulated non-human characters, vol.31, 2011. ,
Simulation and control of skeleton-driven soft body characters, ACM Transactions on Graphics, vol.32, issue.6, 2013. ,
DOI : 10.1145/2508363.2508427
Soft body locomotion, Transactions on Graphics ,
DOI : 10.1145/2185520.2185522
Direct trajectory optimization of rigid body dynamical systems through contact, Algorithmic foundations of robotics X, 2013. ,
DOI : 10.1007/978-3-642-36279-8_32
URL : http://groups.csail.mit.edu/robotics-center/public_papers/Posa12.pdf
Sofa: A multi-model framework for interactive physical simulation, Studies in Mechanobiology Tissue Engineering and Biomaterials, 2012. ,
DOI : 10.1007/8415_2012_125
URL : https://hal.archives-ouvertes.fr/hal-00681539
Formulating dynamic multi-rigid-body contact problems with friction as solvable linear complementarity problems, Nonlinear Dynamics, vol.14, issue.3, 1997. ,
qpOASES: A parametric active-set algorithm for quadratic programming, Mathematical Programming Computation, vol.6, issue.4, 2014. ,
A resilient, untethered soft robot ,
DOI : 10.1089/soro.2014.0008
URL : https://dash.harvard.edu/bitstream/1/16920697/1/21340991.pdf
Crawling and jumping by a deformable robot, The International Journal of Robotics Research, vol.25, issue.5-6 ,
DOI : 10.1177/0278364906065386
Jsel: Jamming skin enabled locomotion, International Conference on Intelligent Robots and Systems, 2009. ,
DOI : 10.1109/iros.2009.5354790
URL : http://www.robotspodcast.com/podcast/mw_images/robotspodcast.com-http___annanmozeika.com_wp-content_uploads_2010_02_Steltz-Mozeika-Rodenberg-Brown-Jaeger-JSEL-Jamming-Skin-Enabled-Locomotion.pdf
Registration by interactive inverse simulation: application for adaptive radiotherapy, International Journal of Computer Assisted Radiology and Surgery, vol.10, 2015. ,
DOI : 10.1007/s11548-015-1175-4
URL : https://hal.archives-ouvertes.fr/hal-01261302
Fem-based deformation control for dexterous manipulation of 3d soft objects, IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01889783
Fast, generic and reliable control and simultation of soft robots using model order reduction, Transactions on Robotics, 2018. ,
DOI : 10.1109/tro.2018.2861900
Volume contact constraints at arbitrary resolution, Transactions on Graphics, vol.29, 2010. ,
DOI : 10.1145/1833349.1778819
URL : https://hal.archives-ouvertes.fr/inria-00502446
