Event-Driven Joint Mobile Actuators Scheduling and Control in Cyber-Physical Systems - Archive ouverte HAL Access content directly
Journal Articles IEEE Transactions on Industrial Informatics Year : 2019
(1) , (2) , (3) , (4) , (1)
1
2
3
4
In cyber-physical systems, mobile actuators can enhance system's flexibility and scalability, but at the same time incurs complex couplings in the scheduling and controlling of the actuators. In this paper, we propose a novel event-driven method aiming at satisfying a required level of control accuracy and saving energy consumption of the actuators, while guaranteeing a bounded action delay. We formulate a joint-design problem of both actuator scheduling and output control. To solve this problem, we propose a two-step optimization method. In the first step, the problem of actuator scheduling and action time allocation is decomposed into two subproblems. They are solved iteratively by utilizing the solution of one in the other. The convergence of this iterative algorithm is proved. In the second step, an on-line method is proposed to estimate the error and adjust the outputs of the actuators accordingly. Through simulations and experiments, we demonstrate the effectiveness of the proposed method.
08673870.pdf (3.88 Mo) Télécharger le fichier
Dates and versions
hal-02080647 , version 1 (26-03-2019)
Identifiers
Cite
Lei Mo, Pengcheng You, Xianghui Cao, Ye-Qiong Song, Angeliki Kritikakou. Event-Driven Joint Mobile Actuators Scheduling and Control in Cyber-Physical Systems. IEEE Transactions on Industrial Informatics, 2019, pp.1-13. ⟨10.1109/TII.2019.2906061⟩. ⟨hal-02080647⟩
143 View
216 Download
Share
