Review on cyber-physical systems, IEEE/CAA J. of Autom. Sinica, vol.4, issue.1, pp.27-40, 2017. ,
Autonomous light control by wireless sensor and actuator networks, IEEE Sensors J, vol.10, issue.6, pp.1029-1041, 2010. ,
Co-design of wireless sensor-actuator networks for building controls, Proc. of IEEE CDC-ECC, pp.5266-5273, 2011. ,
Multicast routing for decentralized control of cyber physical systems with an application in smart grid, IEEE J. Sel. Areas Commun, vol.30, issue.6, pp.1097-1107, 2012. ,
NETWRAP: an NDN based realtime wireless recharging framework for wireless sensor networks, IEEE Trans. Mobile Comput, vol.13, issue.6, pp.1283-1297, 2014. ,
Multinode wireless energy charging in sensor networks, IEEE/ACM Trans. Netw, vol.23, issue.2, pp.437-450, 2015. ,
Charging utility maximization in wireless rechargeable sensor networks, Wirel. Netw, pp.1-13, 2016. ,
Joint power charging and routing in wireless rechargeable sensor networks, Sensors, vol.17, issue.10, pp.1-17, 2017. ,
Distributed collaborative control for industrial automation with wireless sensor and actuator networks, IEEE Trans. Ind. Electron, vol.57, issue.12, pp.4219-4230, 2010. ,
Building-environment control with wireless sensor and actuator networks: centralized versus distributed, IEEE Trans. Ind. Electron, vol.57, issue.11, pp.3596-3605, 2010. ,
ORA-CLE: mobility control in wireless sensor and actor networks, Comput. Commun, vol.35, issue.9, pp.1029-1037, 2012. ,
Distributed node coordination for real-time energy-constrained control in wireless sensor and actuator networks, IEEE Internet Things J, vol.5, issue.5, pp.4151-4163, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01825524
A novel scheme for WSAN sink mobility based on clustering and set packing techniques, IEEE Trans. Autom. Control, vol.56, issue.10, pp.2381-2389, 2011. ,
Handling mobility in wireless sensor and actor networks, IEEE Trans. Mobile Comput, vol.9, issue.2, pp.160-173, 2010. ,
An online optimization approach for control and communication co-design in networked cyber-physical systems, IEEE Trans. Ind. Informat, vol.9, issue.1, pp.439-450, 2013. ,
Control-quality driven design of cyber-physical systems with robustness guarantees, Proc. of IEEE/ACM DATE, pp.1093-1098, 2013. ,
Co-design of cyberphysical systems via controllers with flexible delay constraints, Proc. of IEEE ASP-DAC, pp.225-230, 2011. ,
Distributed multi-actuator control for workload balancing in wireless sensor and actuator networks, IEEE Trans. Autom. Control, vol.56, issue.10, pp.2462-2467, 2011. ,
Linear integer programming methods and approaches -a survey, Cybern. and Inf. Technol, vol.11, issue.1, pp.1-23, 2011. ,
Partitioning procedures for solving mixed-variables programming problems, Numer. Math, vol.4, issue.1, pp.238-252, 1962. ,
Convex optimization, 2004. ,
Accurate prediction of power consumption in sensor networks, Proc. of IEEE EmNetS, pp.37-44, 2005. ,
Prolonging sensor network lifetime through wireless charging, Proc. of IEEE RTSS, pp.129-139, 2010. ,
Branch and bound methods, pp.1-11, 2007. ,
Solving mixed integer linear programs using branch and cut algorithm, 1999. ,
An evolutionary algorithm for polishing mixed integer programming solutions, INFORMS J. Comput, vol.19, issue.4, pp.534-541, 2007. ,
A comparison of optimal methods for local access uncapacitated network design, Ann. Oper. Res, vol.106, issue.1, pp.263-286, 2001. ,
Path tracking control of mobile robots using a quadratic curve, Proc. of IEEE IV, pp.58-63, 1996. ,
Diffusion-based path planning in mobile actuator-sensor networks (mas-net): some preliminary results, Proc. of IEEE SPIE, vol.5421, pp.58-69, 2004. ,
Autonomous vehicle coordination with wireless sensor and actuator networks, ACM Trans. Auton. Adapt. Syst, vol.5, issue.4, p.13, 2010. ,
Mapping on multi/many-core systems: survey of current and emerging trends, Proc. of IEEE/ACM DAC, pp.1-10, 2013. ,
Energy optimization for realtime multiprocessor system-on-chip with optimal DVFS and DPM combination, ACM Trans. Embed. Comput. Syst, vol.13, issue.3, pp.1-111, 2014. ,
QoS-adaptive approximate real-time computation for mobility-aware IoT lifetime optimization, IEEE Trans. Comput.-Aided Design Integr. Circuits Syst, pp.1-12, 2018. ,
